When mounting a DTV or FM antenna outdoors, the coaxial cable run can be exceptionally long and cause signal degradation. Protect your signal strength with the RCA VH200R 12dB signal antenna. This easy to install antenna is equipped with two F-type connectors; the input for connecting to your antenna, cable box, or satellite receiver and the output connects directly to your TV or stereo receiver. This amp easily mounts vertically or horizontally with the included installation hardware and is powered with the included 12 VDC power supply. Dimensions: 5-1/2" H x 2-5/8" W x 1-1/4" D.
