  • RCA Plug Connector Crimp-on For RG-59/U Coax
Parts ExpressPart # 090-263
These crimp-on RCA connectors are specifically designed for use RG-59/U and can be easily terminated in the field.
  • Nickel plating is rugged and attractive
  • Textured barrel provides good grip
  • Assembles with soldering iron, coaxial stripper, and crimp tool
Your Price: $1.04
MSRP: $1.99
Save $0.95 (48%)
71 In Stock
We'll send you an email when RCA Plug Connector Crimp-on For RG-59/U Coax is back in stock or available for preorder.
These RG-59-compatible RCA plugs are perfect for installers or anyone else interested in an economical, easy way to terminate cables. Simply slide the ferrule onto the RG-59, strip the cable end, insert the connector onto the cable with the protruding tube between the center insulator and shielding, slide the ferrule up over the shielding, crimp the ferrule, and put a small amount of solder into the hole in the tip to secure and make contact between the center pin of the RCA and the conductor inside.
Specifications: • Contact plating: nickel • Sold per: each • Finish:nickel  • Termination style: crimp & solder.
Part Number090-263
UPC844632010699
Weight0.0198
GenderMale / Plug
Mounting TypeCable Mount
