  • 3-1/2" 10W Mylar Surface Mount Speaker Light Almond
BUYOUT 3-1/2" 10W Mylar Surface Mount Speaker Light Almond
Factory BuyoutsPart # 299-2126
This surface mount speaker is ideal for reproducing frequencies in the vocal range making it suitable for paging, intercom, and security purposes. The efficient 3" driver uses a poly cone and surround making it acceptable for use in damp locations.
  • Compact size can mount almost anywhere
  • Ideal for commercial or educational applications
  • 12 inch speaker leads for simple connections
  • Poly cone and surround for use in damp locations
BUYOUT $0.95
1837 In Stock
We'll send you an email when 3-1/2" 10W Mylar Surface Mount Speaker Light Almond is back in stock or available for preorder.
Sometimes when we make a surplus buy little gems come rolling out of the boxes, and frankly speaking, this is not one of them. The light almond color is a throwback to the 70's or 80's, one of those decades for sure, so it might be perfectly suited for a retro looking application. The design of the enclosure certainly won't turn any heads. It's square, with grill holes in the front….but it does the job.
The speaker can be surface mounted using the back plate, which is easy to remove, and using the 4 holes found on it you can mount it anywhere--out of site might just be perfect location. The 12 inch long speaker wire makes connections a snap. Buy 1 or 100 today.
Specifications: • Power Handling: 10 watts • Dimensions: 2" D x 4" H x 4" W
BrandFactory Buyouts
Part Number299-2126
UPC848864027197
Weight0.95
