  • 14-Piece Power Nut Driver Set for Impact Drill 1/4" Hex Head SAE and Metric Bits with Holder
Parts ExpressPart # 360-260
Designed to withstand high-torque that impact drills deliver, these nut driver bits are built to last, ensuring that they won't strip or wear down even under intense pressure. If you've ever struggled with driving lag bolts or other bolt head screws that require extra torque, then these bits are your perfect solution. Say goodbye to frustration and hello to efficient, powerful fastening!
  • Heavy-duty metal for long-lasting nonslip nut driving
  • Includes metric and standard size nut drivers for versatility
  • 1/4" shaft fits many powered screwdrivers and drills
Your Price: $4.98
Save $5.01 (50%)
We'll send you an email when 14-Piece Power Nut Driver Set for Impact Drill 1/4" Hex Head SAE and Metric Bits with Holder is back in stock or available for preorder.
Order in the next 0 hr 0 min to ship today. Details
Drive Lag Bolts or other Bolt Head Screws with Confidence when Using an Impact Drill
Our nut driver bits are specifically crafted to fit into powered drills, impact drills or screwdrivers that accept 1/4" hex bits, making them incredibly versatile and compatible with most common tools. With their sturdy construction and reliable performance, they are the ultimate choice for any heavy-duty project.
Multiple Size Bits to Conquer the Job
This set includes a range of sizes to cater to various bolt head dimensions to complete the job. In the SAE measurements, you'll find the following sizes: 3/16", 1/4", 9/32", 5/16", 11/32', 3/8", and 7/16". For metric measurements, the set includes sizes such as 5 mm, 5.5mm, 6mm, 7mm, 8mm, 10mm, and 12mm.
The Right Tool Saves Time
Get ready to tackle those tough projects with confidence and precision. Purchase our heavy-duty metal impact drill nut driver 1/4" shaft bits and discover the difference they can make in your workmanship. Don't let stripped screws or insufficient torque slow you down. Use the best tools available and achieve outstanding results every time.
Part Number360-260
UPC848864074320
Weight0.45
