  • Quest FRA-32412 Raceway Right Angle 1" White 2 Pcs.
CLEARANCE Quest FRA-32412 Raceway Right Angle 1" White 2 Pcs.
2 Questions, 3 Answers or
Quest Technology
Part #261-206
Quest Technology
Part #261-206
Model: FRA-32412
Quest 1" Right Angle Raceway accessories speed up installations by enabling you to simply fit the raceway into the proper accessory to wrap around corners, change directions, split your cables, terminate a run, or run cable down from the ceiling.
  • UV stabilizer to prevent color fading
  • Constructed of flame retardant PVC
  • Fits Quest WireHider, Latching Duct, and Raceway On-A-Roll
  • Can be painted to match any decor
CLEARANCE $6.49
MSRP: $9.99
Save $3.50 (35%)
Order in the next 0 hr 23 min to ship today. Details
1In Stock
Quest Raceway Accessories were designed with the installation professional in mind. Quest created these accessories to eliminate the problem of redirecting raceway and wrapping around corners. These 1" Right Angle Raceway accessories speed up installations by enabling you to simply fit the raceway into the proper accessory to wrap around corners, change directions, split your cables, terminate a run, or run cable down from the ceiling. The white ABS material connections are perfect for completing an aesthetically pleasing installation.
BrandQuest Technology
ModelFRA-32412
Part Number261-206
UPC876630000679
Unit of MeasurePairs
Weight0.1
