  • Quam UL24/8 24" x 24" Lay-in Ceiling Tile Replacement with Dual Loudspeakers
NEW Quam UL24/8 24" x 24" Lay-in Ceiling Tile Replacement with Dual Loudspeakers
QuamPart # 244-3452
Model: UL24/8
The Quam UL24/8 is a dual 8" loudspeaker assembly designed for lay-in installation in 2' x 2' suspended ceiling grids. It combines wide sound coverage with full UL compliance, making it ideal for use in air-handling spaces and emergency signaling systems.
  • Two speakers; one for paging and one for fire alarm/emergency use
  • UL1480 and UL2043 listed for signaling and plenum use
  • 25V/70V with 5 taps on the fire signaling speaker
  • 8 ohm impedance on the paging speaker
  • No assembly required
NEW $230.53
MSRP: $257.00
Save $26.47 (10%)
We'll send you an email when Quam UL24/8 24" x 24" Lay-in Ceiling Tile Replacement with Dual Loudspeakers is back in stock or available for preorder.
UL24/8 is a UL Listed dual speaker unit designed for emergency communication and general paging, all housed in a space-saving tile-replacement configuration. The fire signaling speaker is intended solely for fire alarm and emergency communication use. The paging speaker is designed for standard signaling applications. This 2’ x 2’ unit delivers high voice clarity and efficient performance in a lightweight, low-profile design. The fire alarm speaker features a 4W-25/70V rotary tap transformer and includes a line supervision capacitor. The paging speaker operates with an 8 Ohm impedance. No assembly is needed.
Application
  • Intended Use: Lay-in ceiling tile replacement - FIRE SIGNALING: Fire alarm and mass communication only, PAGING: General signaling only
  • Program Material: Mass notification and emergency communications, signal tones, and voice
  • Installation: Fits in a 2'x 2' or 2'x 4' wide ceiling tile grid
Audio Performance
  • Average Sensitivity at 10' per Tap: FIRE SIGNALING: 1/4W=74.5dB, 1/2=77.3, 1=80.3, 2=83.1, 4=85.5, PAGING: 89dB SPL, 1W/1M
  • Loudspeaker Power Rating: FIRE SIGNALING: 20W RMS, EIA 426 Standard, PAGING: 12W RMS, EIA 426A Standard
  • Magnet Type & Weight: FIRE SIGNALING: BeFe Ceramic, 10 oz. nominal, PAGING: BeFe Ceramic, 5 oz. nominal
  • Frequency Response FIRE SIGNALING: 60Hz - 17kHz, EIA 426 Standard, PAGING: 65Hz - 17kHz, EIA 426A Standard
  • Nominal Coverage Angle: 100° Included Angle, -6dB/2kHz, Half space
  • Audio Connection: 7 ½", Color-coded, Pre-tinned Leads
Component
  • Dimensions:3-1/2" (H) x 23-13/16 " (W) x 23-13/16" (D)
  • Weight:9 lbs.
  • Loudspeaker Model: FIRE SIGNALING: 8C10PAFR, PAGING: 8C5PAX
  • Loudspeaker Specs: FIRE SIGNALING: 8" O.D. loudspeaker, 10 oz. magnet, fire retardant, PAGING: 8" O.D. loudspeaker, 5 oz. magnet
  • Transformer: FIRE SIGNALING: 4W, 25V (yellow) and 70V (red) rotary select with 5 taps (0.25W, 0.50W, 1W, 2W, 4W), PAGING: N/A-8 Ohm impedance
  • Integral Enclosure: 1,283 CID, molded fiber
  • Grille: Perforated steel, with four(4) seismic tie-off points
  • Finish: White powder coat finish
  • Other: FIRE SIGNALING: A 10uF, 150V, line supervision capacitor is included
  • UL Listed 1480: (FIRE SIGNALING) When installed per supplied installation instructions and requirements of NEC/AHJ.
  • UL Listed 2043: (FIRE SIGNALING) Suitable for use in air-handling spaces. Material and construction permits use where ceiling plenum is part of the air handling system.
  • ASTM E84: (FIRE SIGNALING) Includes integral backbox that meets/exceeds flame and smoke test w/ 3hr. burn rating.
  • CSFM Certified #7320-2288:0500: (FIRE SIGNALING) Listed as speakers for use with separately listed compatible fire alarm control units.
  • UL Listed 1480A (Type G): (PAGING) When installed per supplied installation instructions and requirements of NEC/AHJ.
  • UL Listed 2043 (PAGING) Suitable for use in air-handling spaces. Material and construction permits use where ceiling plenum is part of the air handling system.
BrandQuam
ModelUL24/8
Part Number244-3452
UPC848864081274
Weight12.45
Input Rating70V
Mounting StyleDrop-in Tile
Woofer Diameter8"
