  • Quam TCH70 10W-70V Low-Loss Extended LF Speaker Line Matching Transformer
QuamPart # 244-3350
Model: TCH70
The Quam TCH70 is a constant voltage line transformer with multi-tap outputs, designed for use in 70V distributed audio systems.
Your Price: $21.98
Save $5.25 (19%)
We'll send you an email when Quam TCH70 10W-70V Low-Loss Extended LF Speaker Line Matching Transformer is back in stock or available for preorder.
The Quam TCH70 is a constant voltage line transformer with multi-tap outputs, designed for use in 70V distributed audio systems. Primary taps are 10, 5, 2.5, 1.25 and 0.63 watts. Primary leads are 12" pre-cut, color coded; secondary leads are 6" pre-cut and color coded. Extended frequency response of 50 - 20,000 Hz.
BrandQuam
ModelTCH70
Part Number244-3350
UPC844632098239
Weight0.7
