  • Quam SYSTEM 2 8" Wall Mount Slanted Speaker 5W-25/70V White
CLEARANCE Quam SYSTEM 2 8" Wall Mount Slanted Speaker 5W-25/70V White
QuamPart # 244-3050
Model: SYSTEM 2
The SYSTEM 2 by Quam is a slanted full range wall mount white loudspeaker assembly with an 8" O.D and 5 watt-25/70.7V pigtail transformer.
  • 8" O.D. full range speaker
  • 5W-25/70.7V pigtail transformer
  • For indoor environments
  • Program material: Signal tones, voice, and music
  • Made in Chicago, USA
CLEARANCE $85.10
MSRP: $103.62
Save $18.52 (18%)
3 In Stock
We'll send you an email when Quam SYSTEM 2 8" Wall Mount Slanted Speaker 5W-25/70V White is back in stock or available for preorder.
Order in the next 8 hr 38 min to ship today. Details
Quam's SYSTEM 2 has a 5 watt 25/70.7V pigtail transformer, 22 gauge steel baffle, and 16 gauge slanted steel enclosure. Intended use in an indoor environment, mounted on a vertical surface, downward firing for signal tones, voice, and music. Made in Chicago, USA.
Specifications: • 25/70.7V transformer: 5, 2.5, 1.25, 0.63, 0.31 watt • Average sensitivity: 92 dB 1W/1m • Power rating: 12 watts RMS • Max. system output: 99 dB SPL, 5W/1m • Magnet type, weight: BeFe ceramic, 4.8 oz. nominal • Frequency response: 65 Hz - 17 kHz • Nominal coverage angle: 90° included angle, -6 dB/ 2 kHz, half space • Audio connection: 7" color coded pigtails, pre-cut.
BrandQuam
ModelSYSTEM 2
Part Number244-3050
UPC844632096563
Weight10
ColorWhite
ConfigurationFull-range
Input Rating70V|25V
Mounting StyleWall Mount
Woofer Diameter8"
Special FeaturesAngled
