  • Quam SYSTEM 12URSDM 24" x 24" Lay-In Ceiling Tile Speaker with Mount for 3rd Party Hardware
NEW Quam SYSTEM 12URSDM 24" x 24" Lay-In Ceiling Tile Speaker with Mount for 3rd Party Hardware
QuamPart # 244-3451
Model: SYSTEM 12URSDM
The Quam SYSTEM-12URSDM is a 2′ x 2′ tile‐replacement loudspeaker built for commercial ceiling installations where space, safety, and aesthetics matter. It combines a full-range 8″ driver, multiple transformer taps, and UL/air-handling ratings to deliver reliable voice, background music, and signaling performance in finished ceilings.
  • 92 dB sensitivity ensures loud, clear output from modest power
  • 12 W RMS (15 W peak) power capacity supports robust background music and announcements
  • Transformer selectable (25/70 V with tap options) allows flexible installation in distributed speaker systems
  • Frequency response from 65 Hz to 17 kHz delivers clear full-range sound including mid-bass punch and vocal clarity
  • Designed for ceiling tile grid mounting (2′ × 2′) to fit existing ceiling layouts with minimal disruption
  • Fire-retardant enclosure with UL 1480, UL 2043 listings and molded fiber box adds safety in air-handling and commercial spaces
  • Perforated steel grille with seismic tie-off points and white powder coat finish blends into ceiling aesthetics while ensuring secure installation
NEW $162.44
MSRP: $181.82
Save $19.38 (11%)
We'll send you an email when Quam SYSTEM 12URSDM 24" x 24" Lay-In Ceiling Tile Speaker with Mount for 3rd Party Hardware is back in stock or available for preorder.
Order in the next 13 hr 2 min to ship today. Details
The SYSTEM 12URSDM is a fully pre-assembled package designed for fast installation, serving as a 2′ x 2′ lay-in ceiling tile replacement enclosure. It features a powder-coated, perforated steel baffle for durability and a lightweight speaker assembly with an 8″ high-efficiency driver, 5 oz. magnet, and a 4 Watt 25/70V transformer with a rotary tap selector. An integrated electrical box includes a faceplate opening for customer-supplied devices such as warning lights, cameras, fire strobes, or wireless access points.
Delivering high intelligibility, visual appeal, and dependable performance, the SYSTEM 12URSDM is suitable for a wide variety of commercial sound applications. UL Listed with four seismic tie-off points for compliance with most local codes, it installs into a ceiling tile grid in about one minute, reducing labor costs and maximizing efficiency. When you need a reliable, great-sounding speaker that saves time on installation, Quam’s SYSTEM 12URSDM is an ideal choice.
Application
  • Intended Use: Lay-in ceiling tile replacement
  • Program Material: Signal tones, voice and background music
  • Installation: Mounted parallel to the floor plane in a 24" ceiling grid
Audio Performance
  • Average Sensitivity: 92dB SPL, 1W/1M
  • Loudspeaker Power Rating: 12W RMS, EIA 426A Standard
  • Maximum Power Rating:4W @ 25/70V
  • Calculated Output: 98dB SPL, 4W/1M
  • Magnet Weight & Weight: BeFe Ceramic, 5 oz. Nominal
  • Frequency Response: 65Hz - 17kHz, EIA 426A Standard
  • Nominal Coverage Angle: 100° Included Angle, -6dB/2kHz, Half Space
  • Audio Connection: 7.5", Color-coded, Pre-tinned Leads
Component
  • Dimension: 3-1/2" (H) x 23-13/16" (W) x 23-13/16" (D)
  • Weight: 6.37 lbs.
  • Loudspeaker Model: 8C5PAX
  • Loudspeaker Specs: 8" O.D. loudspeaker, 5 oz. magnet
  • Transformer: 4W, 25/70V, rotary select with 5 taps (0.25W, 0.50W, 1W, 2W, 4W)
  • Integral Enclosure: 1,283 CID molded fiber
  • Grille: Standard perforated steel with four (4) seismic tie-off points
  • Finish: White powder coat finish
  • Device Mount: Built-in 4-square with single- and dual-gang adapter
Certification
  • UL Listed 1480:  When installed with supplied installation instructions and requirements of NEC/AHJ. (UEAY, UEAY7- Canada)
  • UL Listed 2043:  Suitable for use in air-handling spaces
BrandQuam
ModelSYSTEM 12URSDM
Part Number244-3451
UPC848864081267
Weight7.6
Input Rating70V
Mounting StyleDrop-in Tile
Woofer Diameter8"
