  • Quam SYSTEM 12/VC 24" x 24" Lay-In Ceiling Tile Speaker 5W-25/70V
QuamPart # 244-3140
Model: SYSTEM 12/VC
Quam's SYSTEM 12/VC is a 24" x 24" lay-in ceiling speaker tile 8" O.D with a 5W-25/70.7V pigtail transformer with volume control.
  • 24" x 24" lay-in speaker tile
  • 5W-25/70.7V pigtail transformer
  • For indoor environments
  • Program material: Signal tones, voice, and music
  • Made in Chicago, USA
Your Price: $157.16
Save $20.03 (11%)
We'll send you an email when Quam SYSTEM 12/VC 24" x 24" Lay-In Ceiling Tile Speaker 5W-25/70V is back in stock or available for preorder.
Order in the next 6 hr 20 min to ship today. Details
The SYSTEM 12/VC by Quam is a complete loudspeaker assembly with an 8" O.D., full range loudspeaker, 5 watt-25/70.7V pigtail transformer with volume control, perforated steel baffle, and integral molded fiber enclosure. Intended use in an indoor environment, mounted parallel to floor plane in a 24" wide suspended ceiling tile grid for signal tones, voice, and music. Note: not UL listed. Made in Chicago, USA.
Specifications: • 25/70.7V transformer: 5, 2.5, 1.25, 0.63, 0.31 watt • Average sensitivity: 92 dB 1W/1m • Power rating: 12 watts RMS • Max. system output: 99 dB, 5W/1m • Magnet type: weight: BeFe ceramic, 4.8 oz. nominal • Frequency response: 65 Hz - 17 kHz • Nominal coverage angle: 100° included angle, -6 dB/ 2 kHz, half space • Audio connection: 7" long labeled, tinned wires, pre-cut.
BrandQuam
ModelSYSTEM 12/VC
Part Number244-3140
UPC844632097386
Weight7.85
Input Rating70V|25V
Mounting StyleDrop-in Tile
Woofer Diameter8"
Special FeaturesEnclosed Back-Volume Control
