  • Quam SYSTEM 12/8 24" x 24" Lay-In Ceiling Tile Speaker 8 Ohm
QuamPart # 244-3138
Model: SYSTEM 12/8
Quam's SYSTEM 12/8 is a 24" x 24" lay-in ceiling speaker tile 8" O.D with an 8 ohm nominal impedance.
  • 24" x 24" lay-in speaker tile
  • 8 ohm nominal impedance
  • For indoor environments
  • Program material: Signal tones, voice, and music
  • Made in Chicago, USA
Your Price: $118.11
Save $12.64 (10%)
We'll send you an email when Quam SYSTEM 12/8 24" x 24" Lay-In Ceiling Tile Speaker 8 Ohm is back in stock or available for preorder.
The SYSTEM 12/8 by Quam is a complete loudspeaker assembly with an 8" O.D., full range loudspeaker, perforated steel baffle, and integral molded fiber enclosure. Nominal impedance is 8 ohms. The SYSTEM 12/8 is UL Listed 1480- (UEAY, UAEY7-Canada) when installed in accordance with supplied installation instructions, requirements of NEC and AHJ. Intended use in an indoor environment, mounted parallel to floor plane in a 24" wide suspended ceiling tile grid for signal tones, voice, and music. Made in Chicago, USA.
Specifications: • Average sensitivity: 92 dB 1W/1m • Power rating: 12 watts RMS • Max. system output: 103 dB, 12W/1m • Magnet type: weight: BeFe ceramic, 4.8 oz. nominal • Frequency response: 65 Hz - 17 kHz • Nominal coverage angle: 100° included angle, -6 dB/ 2 kHz, half space • Audio connection: 7" long labeled, tinned wires, pre-cut.
BrandQuam
ModelSYSTEM 12/8
Part Number244-3138
UPC844632096792
Weight7
Input Rating8 ohm
Mounting StyleDrop-in Tile
Woofer Diameter8"
Special FeaturesEnclosed Back-UL1480
