  • Quam C5/B70/W 8" Speaker Screw-through Baffle 4W-70V
CLEARANCE Quam C5/B70/W 8" Speaker Screw-through Baffle 4W-70V
1 Question, 3 Answers or
Quam
Part #244-3108
Quam
Part #244-3108
Model: C5/B70/W
Quam's C5/B70/W is an 8" ceiling speaker with screw mount baffle and a 4 watt-70.7V transformer.
  • 8" framed speaker
  • 4W-70.7V transformer
  • For indoor environments
  • Program material: Signal tones, voice, and music
  • Made in Chicago, USA
CLEARANCE $43.90
MSRP: $44.14
Save $0.24 (1%)
Quantity:Qty: 1-5 $43.90/ea
Quantity:Qty: 6+$42.80/ea
Order in the next 0 hr 24 min to ship today. Details
5In Stock
The C5/B70/W by Quam is a complete loudspeaker assembly with an 8" O.D., 25 watt dual-cone full range loudspeaker, 4 watt-70.7V transformer, and 22 gauge steel screw mount baffle. Baffle finish is a white baked epoxy hybrid. Intended use is ceiling mounted in an indoor environment downward facing for signal tones, voice, and music. Made in Chicago, USA.
Specifications: • 70.7V transformer: 4, 2, 1, 0.5, 0.25 watt • Baffle: Screw mount • Average sensitivity: 92 dB 1W/1m • Power rating: 12 watts RMS • Calculated output: 98 dB SPL, 4W/1m • Magnet type: weight: BeFe ceramic, 4.8 oz. nominal • Frequency response: 65 Hz - 17 kHz • Nominal coverage angle: 90° included angle, -6 dB/ 2 kHz, half space • Audio connection: 7" long, color-coded tinned wires, pre-cut.
BrandQuam
ModelC5/B70/W
Part Number244-3108
UPC844632097270
Weight3.7
Input Rating70V
Mounting StyleIn-ceiling
Woofer Diameter8"
