  • Quam C10X/BU/WS 8" Speaker Studded Baffle 5W-25/70V
CLEARANCE Quam C10X/BU/WS 8" Speaker Studded Baffle 5W-25/70V
QuamPart # 244-3114
Model: C10X/BU/WS
Quam's C10X/BU/WS is an 8" ceiling speaker with studded mount baffle and 5 watt-25/70.7V pigtail transformer.
  • 8" O.D. full range speaker
  • 5W-25/70.7V transformer
  • For indoor environments
  • Program material: Signal tones, voice, and music
  • Made in Chicago, USA
CLEARANCE $35.64
MSRP: $49.90
Save $14.26 (29%)
2 In Stock
We'll send you an email when Quam C10X/BU/WS 8" Speaker Studded Baffle 5W-25/70V is back in stock or available for preorder.
Order in the next 8 hr 39 min to ship today. Details
The C10X/BU/WS by Quam is a complete loudspeaker assembly with an 8" O.D., full range loudspeaker, 5 watt-25/70.7V pigtail transformer, and 22 gauge steel stud mount baffle. Baffle finish is a white baked epoxy hybrid. Intended use is ceiling mounted in an indoor environment downward facing for signal tones, voice, and music. Made in Chicago, USA.
Specifications: • 25/70.7V transformer: 5, 2.5, 1.25, 0.63, 0.31 watt • Baffle: Stud mount • Average sensitivity: 95 dB 1W/1m • Power rating: 20 watts RMS • Max. system output: 102 dB SPL, 5W/1m • Magnet type: weight: BeFe ceramic, 10 oz. nominal • Frequency response: 60 Hz - 17 kHz • Nominal coverage angle: 90° included angle, -6 dB/ 2 kHz, half space • Audio connection: 7" long, color-coded tinned wires, pre-cut.
BrandQuam
ModelC10X/BU/WS
Part Number244-3114
UPC844632097300
Weight4.3
Input Rating70V|25V
Mounting StyleIn-ceiling
Woofer Diameter8"
