  • Quam 8C5PAX 8" Speaker 8 Ohm
CLEARANCE Quam 8C5PAX 8" Speaker 8 Ohm
QuamPart # 244-3210
Model: 8C5PAX
Quam's 8C5PAX is an 8" O.D. 8 ohm loudspeaker with a concentric mount hard fiber HF cone.
  • 8" O.D. loudspeaker
  • For indoor environments
  • Program material: Signal tones, voice, and music
  • Made in Chicago, USA
We'll send you an email when Quam 8C5PAX 8" Speaker 8 Ohm is back in stock or available for preorder.
The Quam 8C5PAX is an 8" O.D., 8 ohm loudspeaker with a concentric mount hard fiber HF cone. The finish is a black baked epoxy hybrid. Intended use in a wide frequency response replacement loudspeaker or combined with recommended Quam components to form a complete loudspeaker system. Use in an indoor environment for signal tones, voice, and music. Made in Chicago, USA.
Specifications: • Average sensitivity: 92 dB 1W/1m • Power rating: 12 watts RMS • Calculated output: 103 dB SPL, 10W/1m • Magnet type, weight: BeFe ceramic, 4.8 oz. nominal • Frequency response: 65 Hz - 17 kHz • Nominal coverage angle: 100° included angle, -6 dB/ 2 kHz, half space • Mounting: Eight 1/4" holes spaced 45° apart on 7-5/8" circle • Audio connection: 0.205" spade lug.
BrandQuam
Model8C5PAX
Part Number244-3210
UPC844632097584
Weight1.42
Input Rating8 ohm
Mounting StyleIn-ceiling
Woofer Diameter8"
Special FeaturesWithout Baffle
