  • Quam 4C3PA 4" Speaker 8 Ohm
QuamPart # 244-3206
Model: 4C3PA
Quam's 4C3PA 4" square frame speaker is 8 ohms with a cloth surround.
  • 4" square frame loudspeaker
  • For indoor environments
  • Program material: Signal tones, voice, and music
  • Made in Chicago, USA
Your Price: $22.98
MSRP: $23.04
Save $0.06 (0%)
We'll send you an email when Quam 4C3PA 4" Speaker 8 Ohm is back in stock or available for preorder.
The 4C3PA by Quam is a 4" square frame, 8 ohm loudspeaker with cloth surround. Finish is a black baked hybrid epoxy. Intended use in an indoor environment as a wide frequency response replacement loudspeaker or combined with recommended Quam components to form a complete loudspeaker assembly. For signal tones, voice, and music. Made in Chicago, USA.
Specifications: • Average sensitivity: 96 dB 1W/1m • Power rating: 10 watts RMS • Calculated output: 107 dB SPL, 10W/1m • Frequency response: 80 Hz - 10 kHz • Nominal coverage angle: 90° included angle, -6 dB/ 2 kHz, half space • Mounting: Four 1/4" holes spaced 90° apart on 4-11/16" circle • Audio connection: 0.205" spade lug.
BrandQuam
Model4C3PA
Part Number244-3206
UPC844632097560
Weight0.95
Input Rating8 ohm
Mounting StyleIn-ceiling
Woofer Diameter4"
Special FeaturesWithout Baffle
