  • QSC AD-ID8T-BK IntelliDock Mounting System with 70/100V Transformer
CLEARANCE QSC AD-ID8T-BK IntelliDock Mounting System with 70/100V Transformer
QSC AudioPart # 999-6270
The QSC AD-ID8-BK IntelliDock Mounting System with 70/100V Transformer is designed to mount the AD-S82 and AD-S82H to the wall or ceiling. The speaker mount features quickly connect latch that allows for easy attachment and disconnect from the speaker.
  • Mount specifically designed for the QSC AD-S82 and AD-S82H speakers
  • Easily accommodate install wiring with an accessible cable management system
  • Ball-type joint allows you to adjust speaker position
  • Built-in 70/100V transformer
CLEARANCE $83.01
MSRP: $128.00
Save $44.99 (35%)
1 In Stock
We'll send you an email when QSC AD-ID8T-BK IntelliDock Mounting System with 70/100V Transformer is back in stock or available for preorder.
The QSC AD-ID8-BK IntelliDock Mounting System with 70/100V Transformer is designed to mount the AD-S82 and AD-S82H to the wall or ceiling. The speaker mount features quickly connect latch that allows for easy attachment and disconnect from the speaker. A ball-type joint makes the speaker easy to adjust positioning after install. The mount also features an easily accessible cable management system for installation wiring.
BrandQSC Audio
Part Number999-6270
UPC684284043894
Weight8.4
