  • Q-Bit SQ1000-S Outlet Box Cut-In Saw for Multi-Tools
MagnepullPart # 365-637
Model: SQ-1000
Cut perfect outlet box holes every time with the Qbit SQ1000-S.
  • Cuts drywall holes in seconds
  • Fits metal and plastic boxes
  • Exact cut every time
  • Safe to use
  • Heavy duty metal construction won't crack under pressure
  • Fits all major brand multi-tools without an adapter
  • Made in the USA
Your Price: $45.00
MSRP: $50.00
Save $5.00 (10%)
Out of Stock
We'll send you an email when Q-Bit SQ1000-S Outlet Box Cut-In Saw for Multi-Tools is back in stock or available for preorder.
Save time by cutting perfect outlet holes 2-3/8" x 3-3/4" every time. Normally to cut a square outlet hole in drywall you would need a template, drill, and a drywall saw. With the Qbit SQ1000-S you only need a variable speed oscillating multi-function tool to cut the hole. It never cuts the hole too big or too small. Finish the job quicker with the SQ1000-S saw bit.
BrandMagnepull
ModelSQ-1000
Part Number365-637
UPC857842006000
Weight0.35
