  • Pyle PWA15BT In-Wall Wall Plate Audio Control Amplifier with Bluetooth USB Microphone & Aux Inputs
CLEARANCE Pyle PWA15BT In-Wall Wall Plate Audio Control Amplifier with Bluetooth USB Microphone & Aux Inputs
Pyle AudioPart # 310-2682
Model: PWA15BT
Add convenient audio control with the Pyle PWA15BT in-wall / wall plate audio control receiver. Built-in Bluetooth allows you to stream music to a connected intercom or speaker system hassle-free, while the amplifier can deliver up to 100 watts of power to your speakers -- perfect for home or office applications.
  • Install the system on any wall in the home or office to unlock versatile sound
  • Bluetooth wireless music streaming ability
  • Connect and stream audio from external devices with the convenient front-panel 3.5 mm Aux jack
  • The rear panel speaker terminal block allows you to connect the receiver to a pair of speakers
  • Microphone paging and speaker control made easy
CLEARANCE $54.09
Save $16.90 (24%)
3 In Stock
We'll send you an email when Pyle PWA15BT In-Wall Wall Plate Audio Control Amplifier with Bluetooth USB Microphone & Aux Inputs is back in stock or available for preorder.
Order in the next 1 hr 1 min to ship today. Details
Control Bluetooth wireless music streaming in any room with the Pyle in-wall amplifier system. The PWA15BT wall plate receiver adds convenient microphone paging ability along with simple source audio control. Install the system on any wall in the home or office to unlock versatile sound configuration that is easily accessible. Built-in Bluetooth allows you to stream music to a connected intercom or speaker system hassle-free.
Enjoy features like rotary control volume adjustment, 1/4'' mic input, USB port for device charging -- along with an Aux (3.5 mm) audio jack for connecting and streaming audio from external devices. The rear panel speaker terminal block allows you to connect the receiver to a pair of speakers. Universal standard size single-gang plate fits most deep electrical boxes and allows for a clean installation.
Line level audio is typically supplied via the front 3.5 mm input jack -- audio may be alternatively supplied via the black/white/gray pigtail leads located on the rear of the amplifier receiver wall plate.
Features:
• Aux (3.5 mm) input
• USB port for device charging (1A)
• 1/4'' microphone input*
• Rotary master volume level control
• Speaker terminal block to connect two Speakers
• Input selector switch (stereo, mic, Bluetooth)
• LED indicator lights
• Power On/Off switch
• Built-in safety: circuit and overload protection
• Accessories Included: Power adapter & wall plate cover
*Mic only works when switched to microphone mode
Bluetooth Connectivity:
• Connect & stream audio from your favorite devices (smartphones, tablets, MP3 players, laptops, computers, etc.)
• Bluetooth network name: 'BT-RY' (no password required)
• Wireless range: 30 ft. (10m)
Technical Specs:
• Power output: 40 watts RMS/100 watts peak
• Mic input type: Dynamic
• Power amp type: Stereo class T
• Minimum load resistance: 4 ohms
• T.H.D.: 0.06% (8 ohm, 1 kHz)
• Power draw: 2 amps
• Input power: 12V DC (included adapter operates on 100-240 VAC, 50/60 Hz)
BrandPyle Audio
ModelPWA15BT
Part Number310-2682
UPC068888757270
Weight0.85
