  • Pyle PT8000CH 19" Rack Mount 8000 Watt 8 Ch Amplifier
Pyle AudioPart # 310-2560
Model: PT8000CH
Pyle Pro 's PT8000CH pro amplifier has 8 channels that each support up to 1,000 watts each making it the ideal choice for use in home theater, stereo, multi-room, and commercial applications.
  • Five color LED display graphic volume display
  • 4 Channel capable bridgeable amplifier
  • Independent channel level controls
  • Each channel can be set is a Left/Right/Mono of the Bus/AUX input
  • Adjoining channels are bridgeable
  • 12 VDC control output allows for remote trigger of auxiliary devices
  • Pass through output allows linking (Daisy-chaining) of additional amplifiers
Your Price: $439.28
Save $50.71 (10%)
We'll send you an email when Pyle PT8000CH 19" Rack Mount 8000 Watt 8 Ch Amplifier is back in stock or available for preorder.
Order in the next 3 hr 1 min to ship today. Details
This massive, powerful amp pushes 8,000 watts of bone-shattering sound in a rack-mountable package! Each channel supports up to 1,000 watts maximum for a sound that's truly colossal and can be assigned to the left, right, or mono channel of the input. Adjoining channels are bridgeable for even more power. Two RCA inputs take anything you want to hook up – TVs, receivers, CD players, laptops, MP3 players, etc. Plus, you can use the bus outputs to daisy chain this receiver to other audio sources. Five-color LED display on the front shows you your levels – so you'll know if you're too loud or too soft. Each channel has individual protection circuitry to keep your equipment safe. Runs on 110 or 220V.
Complete Your Multizone Audio System
Create your multi-zone audio system by adding subwoofers, floor speakers, center channel speakers, bookshelf speakers, or ceiling/in-wall speakers. Add additional control to your system by adding additional in-wall volume controls.
Additional Accessories:
Complete your system with the necessary accessories such as bulk wire & cable, volume controls, wall plates, racks, and cooling equipment.
BrandPyle Audio
ModelPT8000CH
Part Number310-2560
UPC068888899031
Weight57.15
Output Channels8
Power Output (RMS Per Channel @ 8 ohms)101 - 250 WattsWatts
Power (RMS/Channel 8 ohms)51 - 100 Watts
Weight Range40 to 49 lbs.
