  • Pyle PT610 Rack Mount PA Amplifier/Mixer
CLEARANCE Pyle PT610 Rack Mount PA Amplifier/Mixer
Pyle AudioPart # 248-430
Model: PT610
When you need power, look to Pyle Pro's extensive lineup of rack-mount power amps.
  • Rack mountable
  • Aux level control
  • Inputs: 3 mic (combo 1/4"/XLR jacks), one mic/CD switchable (combo 1/4"/XLR or RCA jacks)
  • Clip protection circuitry
  • Adjustable feedback notch filter
  • Front mounted headphone jack
  • Output level VU meter
We'll send you an email when Pyle PT610 Rack Mount PA Amplifier/Mixer is back in stock or available for preorder.
When you need power, look to Pyle Pro's extensive lineup of rack-mount power amps. This dynamic amplifier range offers different combinations of features, making it possible for you to select a model that's perfect for your application. Two (2) year limited manufacturer's warranty.
Specifications: • Output power: 100 watts (THD 2%, 8 ohm load, 1kHz), 200 watts max (8 ohm load) • THD (at 70W, 8 ohm load, 1 kHz): MIC (phone/XLR jack): 0.35%, CD: 0.20%, Line: 0.20% • Frequency response (1 watt, ± 3 dB): MIC (phone/XLR jack): 75-20,000 Hz, CD: 60-20,000 Hz, Line: 60-20,000 Hz • Input sensitivity (2% THD, 1 kHz): MIC: 1 mV, CD: 150 mV, Line: 150 mV • Signal-to-Noise ratio: MIC: 60 dB, CD: 73 dB, Line: 73 dB • Notch filter range: 300-3,000 Hz, -12 dB depth • Noise level (with inputs shorted): 0.75 mV • Power requirement: 120 VAC, 60 Hz • Dimensions: 4-3/16" H x 18-15/16" W x 11-15/16" D • Net weight: 25-3/4 lbs. Specifications provided by manufacturer.
BrandPyle Audio
ModelPT610
Part Number248-430
UPC068888708616
Weight25.82
Power Output (RMS @ 70V)25W to 50W
Weight Range20 to 29 lbs.
