  • Pyle PLMRMB2CW 2 x 300W Marine Grade Amplifier Kit with Bluetooth
Pyle AudioPart # 267-7434
Model: PLMRMB2CW
Give your sound system a 600W boost with the PLMRM2CW waterproof micro marine 2 x 300W Max amplifier on boats, motorcycles, ATVs, or other modes of transportation where moist environments damage standard amplifiers.
  • Power protection circuitry
  • Anti-thump turn-on
  • Remote volume gain control for convenient increase or decrease in sound without touching the amp
  • Includes waterproof bag with 3.5 mm jack to protect smartphones or other small media devices
  • RCA line input
  • Adjustable high low level inputs
  • 2 ohms stereo stable
Your Price: $65.98
Save $13.01 (16%)
We'll send you an email when Pyle PLMRMB2CW 2 x 300W Marine Grade Amplifier Kit with Bluetooth is back in stock or available for preorder.
Order in the next 2 hr 42 min to ship today. Details
The Pyle PLMRM2CW micro size amplifier system comes with everything you need to give your sound system a serious boost while providing protection against the elements. Add up to 400 Watt Max power (200 watt power on each of the 2 channels). Create a fitting and truly custom installation with this sound system that mounts in tight, exposed spaces.
Input Level: Set the input sensitivity of the amp. If you are connecting to a LINE level source (typically an RCA type connection) then the switch should be in the LINE (out) position. When connecting to speaker outputs, headphone, or high level car radio sources then set the switch to the SPEAKER position.
Polarity: This switch allows the user to optimize bass performance in the case that there are more than 1 set of loudspeakers producing bass in the system. Play some music with strong bass content and listen with the switch alternately in the NORMAL and REVERSE position until it can be determined which settings results in more pleasing bass response.
Gain Control: Adjusts the overall level of the amplifier. When using the amp without volume control, the level should be set to achieve a balance with other loudspeakers in the system. As a rule, you should keep the gain settings as low as possible while still ensuring that the system will reach its full output power.
Waterproof Remote Volume Control: When installed, this volume control will power off the amp when turned all the way down.
RCA Stereo Input: Connect external audio devices like an iPod or just about any other MP3 player into the 3.5 mm stereo input jack.
Waterproof Poly Bag with 3.5 mm Jack: Enjoy playing your favorite audio files around moist environments or in-climate weather while the bag protects your smartphone or media device from water damage.
Built-in Mounting Brackets: Included hardware provides easy and convenient installation. Attach the amplifier to a compartment or panel with just a few screws.
Specifications:• Power output: 2 x 100 watts RMS at 4 ohms, 2 x 200 watts max at 4 ohms, 2 x 300 watts RMS at 2 ohms • THD: < 0.05% • S/N ratio: > 95 dB • Channel separation: > 65 dB • Frequency response: 10 Hz- 40 kHz • Fuse: 10A • Dimensions: 4.1" L x 3.4" W x 1.4" H.
BrandPyle Audio
ModelPLMRMB2CW
Part Number267-7434
UPC068888775649
Weight1.7
Input TypeRCA Line Level-Speaker Level
Output Channels2
RMS Power Output (4 Ohms)100
Special Features2 ohm Stable
