  • Pyle PLCM10 License Plate Mount Rear View Camera
CLEARANCE Pyle PLCM10 License Plate Mount Rear View Camera
Pyle AudioPart # 267-7008
Model: PLCM10
Eliminate the worry of an unexpected blind spot when having your car in reverse. Now you can see all angles when backing up with Pyle's PLCM10 rear view camera. Mounts directly to the license plate.
  • Mounts directly to the license plate
  • Standard composite video output
  • High resolution: 380 TV lines
  • Low light illumination: 1.5 lux/f1.2
CLEARANCE $14.57
MSRP: $17.92
Save $3.35 (19%)
10 In Stock
We'll send you an email when Pyle PLCM10 License Plate Mount Rear View Camera is back in stock or available for preorder.
Order in the next 3 hr 44 min to ship today. Details
Eliminate the worry of an unexpected blind spot when having your car in reverse. Now you can see all angles when backing up with Pyle's PLCM10 rear mount camera. Mounts directly to the license plate. Your view is still visible in the dark with a night vision sensor. One-year manufacturer's warranty.
Specifications: • Resolution: 380 TV lines • Image sensor: Ov 7910 Color CMOS • Lens: 6 mm, 92° • Low light illumination: 1.5 lux/f1.2 • Video output: RCA 1.0Vp-p composite video @ 75 ohms • Output standard: PAL/NTSC • Power requirements: DC 12V • Operating temperature: 14°F ~ 122°F (-10°C ~ 50°C) • Dimensions: 8" L x 1.3" H x 1.26" D.
BrandPyle Audio
ModelPLCM10
Part Number267-7008
UPC068888885324
Weight0.45
