  • Pyle PFA600BU Compact Desktop PA Amplifier System
CLEARANCE Pyle PFA600BU Compact Desktop PA Amplifier System
Pyle AudioPart # 310-2690
Model: PFA600BU
The Pyle PFA600BU is a compact desktop public address amplifier system designed to provide versatile audio control for various settings, including small events, conferences, and home audio setups. With a maximum power output of 300 watts, it offers robust sound amplification suitable for both speech and music applications. Its user-friendly interface and multiple input options make it a practical solution for diverse audio needs.
  • Bluetooth 4.0 connectivity for seamless wireless audio streaming
  • Dual 1/4-inch microphone inputs for versatile vocal applications
  • USB flash drive and SD memory card readers for MP3 playback
  • Up to 32GB in digital memory supported for USB/SD
  • FM radio tuner with digital LCD display for access to local broadcasts
  • Integrated button-activated siren alarm function for emergency situations
  • Independent volume controls for precise audio adjustments
We'll send you an email when Pyle PFA600BU Compact Desktop PA Amplifier System is back in stock or available for preorder.
The PFA600BU features built-in Bluetooth 4.0 technology, enabling wireless music streaming from compatible devices such as smartphones, tablets, and laptops, with a range of up to 30 feet. It includes two 1/4-inch microphone input jacks, allowing for simultaneous use of multiple microphones, making it ideal for presentations and karaoke sessions. The amplifier supports MP3 digital audio file playback through its USB flash drive and SD memory card readers, accommodating media up to 32GB in size. An FM radio tuner with a digital LCD display provides access to local radio stations, while the auxiliary input allows for the connection of various external audio sources. The integrated button-activated siren alarm function adds an extra layer of utility for emergency announcements. Independent rotary volume controls for each audio channel enable precise adjustments to achieve the desired sound balance.
Technical Specifications
  • Power Output: 300 Watt MAX
  • Frequency Response: +/-3dB, 100Hz-20kHz
  • Impedance: 4/8/16 Ohm
  • T.H.D.: <1.0%
  • S/N Ratio: >70dB, Mic <80dB, Line>80dB
  • Mic Input Sensitivity: 8mV
  • Maximum USB/SD Memory Support: Up to 32GB
  • Digital Filetype Playback Support: MP3/WAV/WMA
  • Remote Control Battery: (1) x CR-2025 (included)
  • Speaker Output: 4-16Ω
  • Power Switch Selectable: AC/Off/DC
  • Power Supply: 110V, 60Hz (12V DC Input)
  • Dimensions (L x W x H): 9.84’’ x 8.26’’ x 2.76’’
  • Weight: 5.49 lbs.
BrandPyle Audio
ModelPFA600BU
Part Number310-2690
UPC842893111452
Weight5.49
