  • Pyle PFA220BT Home Audio Desktop Bluetooth Amplifier
CLEARANCE Pyle PFA220BT Home Audio Desktop Bluetooth Amplifier
Pyle AudioPart # 310-2688
Model: PFA220BT
The Pyle PFA220BT is a compact and versatile mini amplifier system designed to deliver powerful audio performance for home use, small events, or personal entertainment. Featuring Bluetooth connectivity, MP3 playback support, and RCA L/R inputs, it offers seamless compatibility with a wide range of devices. Its intuitive controls and space-saving design make it a reliable and user-friendly addition to any setup.
  • Bluetooth technology for seamless wi\eless audio streaming.
  • MP3 digital audio file playback via SD memory card and USB flash drive readers
  • USB port that doubles as a device charging station
  • Digital LCD display panel with touch button controls for easy operation
  • RCA audio inputs (L/R) for a stable, wired connection
  • 1/4'' microphone input jack for added functionality
  • Remote control for easy music and volume adjustments
Fosi Audio ZA3 Balanced Stereo Amplifier 235W with 48V Power Supply
Price: $149.99Part # 235-264
See all items in Home Audio Amplifiers
We'll send you an email when Pyle PFA220BT Home Audio Desktop Bluetooth Amplifier is back in stock or available for preorder.
The PFA220BT amplifier features built-in Bluetooth technology, allowing you to stream wireless audio effortlessly from your favorite devices, including smartphones, tablets, and computers. It supports MP3 digital audio file playback through SD memory card and USB flash drive readers, providing multiple options for enjoying your music collection. The USB port also functions as a charging station, keeping your devices powered while you listen. The digital LCD display panel with touch button controls offers intuitive operation, making it easy to adjust settings. With RCA audio inputs (L/R), the amplifier also offers a stable, wired connection to various external devices. Additionally, the 1/4'' microphone input jack adds functionality for public speaking or karaoke sessions. The push-type speaker L/R terminals provide secure and straightforward connections, ensuring reliable performance.
Technical Specifications
  • Power Output: 120 Watt (60 Watt x 2 @ 4Ohm)
  • Class-T Digital Amp Circuit Design
  • Frequency Response: 20Hz - 20kHz
  • Rate Level Audio Input: 350mv/47k Ω
  • Rate Level Mic Input: 8mv/600 Ω
  • Tone Control (Bass/Treble): +/- 8dB
  • Master Channel Separation: >45dB
  • Signal-to-Noise Ratio (SNR): >80dB
  • Signal-to-Noise Master Channel: >71dB
  • Total Harmonic Distortion(THD): <0.4%
  • Power: DC 12 Volt /2A
  • Maximum USB/SD Memory Support: 16 GB
  • Dimensions: 10.5'' x 8.8'' x 2.8''
BrandPyle Audio
ModelPFA220BT
Part Number310-2688
UPC068888754514
Weight1.55
