  • Pyle PDWR59BTB 5.25" Pro-Active Bluetooth Speaker Pair 600W Black
CLEARANCE Pyle PDWR59BTB 5.25" Pro-Active Bluetooth Speaker Pair 600W Black
Pyle AudioPart # 310-2466
Model: PDWR59BTB
The Pyle PDWR59BTB is a pair of 5.25-inch Pro-Active Wireless Bluetooth Streaming Speakers with a robust 300-watt RMS output, offering 2-way full-range stereo sound for versatile wall-mounted installation. Perfect for home, garage, porch, or enclosed patio setups, these speakers provide a rich and dynamic listening experience.
  • Bluetooth 5.0 wireless streaming for smooth audio playback
  • Active speakers eliminate the need for a separate amplifer
  • Adjustable angle wall mount brackets for flexible placement
  • Aux (3.5mm) input and RCA (L/R) jacks for connectivity options
  • Durable polypropylene cabinet for long-lasting use
  • Rotary volume, bass, and treble controls for personalized sound
  • Removable steel speaker grills for easy cleaning and maintenance.
We'll send you an email when Pyle PDWR59BTB 5.25" Pro-Active Bluetooth Speaker Pair 600W Black is back in stock or available for preorder.
The PDWR59BTB system boasts a maximum power output of 600 watts and an RMS power of 300 watts, ensuring ample volume and clarity for various applications. Its frequency response ranges from 70 Hz to 16 kHz, providing a full spectrum of sound. The package includes an active wall speaker, a passive wall speaker, mounting hardware, and a power cable, offering a complete setup for immediate use.
Constructed with heavy-duty polypropylene material, the speakers are built to withstand various environmental conditions, ensuring longevity and reliable performance. The quick-connect screw-type speaker terminals and included mounting hardware make installation straightforward, whether you're setting up in a permanent location or planning to move the system as needed. With its blend of durability, high-quality sound, and modern connectivity, the Pyle PDWR59BTB speaker system is an excellent choice for enhancing your audio experience both indoors and outdoors.
Technical Specifications
  • Power Supply: 600W (MAX Power)
  • RMS Power: 300W
  • Speaker Size: Sound System: 5.25'' Subwoofers: 0.5'' Tweeter
  • Subwoofer Type: 5.25'' PP Polymer
  • Tweeter Type: 0.5'' Mylar Dome
  • Frequency Response: 70-16 kHz (+/-3dB)
  • Speaker Impedance: 8 Ohm
  • Audio Sensitivity: 86dB
  • Construction Material: Polypropylene
  • Power Cable Length: 3.94 ft.
  • Power Output: 120-240V
  • Single Speaker Dimensions (L x W x H): 7.2'' x 6.5'' x 9.6''
  • Weight: 11.1 lbs.
BrandPyle Audio
ModelPDWR59BTB
Part Number310-2466
UPC842893144634
Unit of MeasurePairs
Weight11.1
