  • Pyle PDICLE35 3.5" LED Home In-Wall / Ceiling Speaker Pair
CLEARANCE Pyle PDICLE35 3.5" LED Home In-Wall / Ceiling Speaker Pair
Pyle AudioPart # 310-2468
Model: PDICLE35
The Pyle PDICLE35 is a versatile in-wall/in-ceiling speaker system designed to deliver high-quality stereo sound while seamlessly integrating into your home or office environment. Each speaker features a built-in LED light, providing both audio reinforcement and illumination. The round design and flush-mount capability make these speakers ideal for custom installations on virtually any flat surface, ensuring a clutter-free space.
  • Built-in LED lights for combined illumination and audio
  • High-compliance 1/2’’ polymer tweeter for crisp sound reproduction
  • Aluminum alloy frame housing for enhanced safety and heat resistance
  • Spring-loaded clips for easy and secure installation
  • Stain-resistant grill covers for a clean appearance
  • Includes cut-out template for precise installation
CLEARANCE $43.69
Save $40.30 (48%)
1 In Stock
We'll send you an email when Pyle PDICLE35 3.5" LED Home In-Wall / Ceiling Speaker Pair is back in stock or available for preorder.
Order in the next 9 hr 6 min to ship today. Details
With a maximum power output of 140 watts, the PDICLE35 speakers offer robust sound reproduction suitable for various audio applications. The built-in 5W white LED lights provide a brightness of 650 lumens, adding functional lighting to your space. With a sensitivity of 90 dB, and a frequency response range of 60 Hz to 20 kHz, these speakers are guaranteed to deliver quality audio reinforcement.
The package includes two 3.5-inch LED speakers, LED light control adapters, and speaker connection wires, providing everything needed for a straightforward installation. Whether you're upgrading your home theater system or adding background music to your office, the Pyle PDICLE35 speakers offer a sleek and functional solution.
Technical Specifications
  • MAX Power Output: 140 Watt
  • Light Bulb Type: White LED Bulb, 5 Watt
  • Brightness: 650 Lumen
  • Impedance: 8 Ohm
  • Sensitivity: 90 dB
  • Frequency Response: 60-20 kHz
  • Total Dimensions (Diameter x Depth): 4.7’’ x 2.8’’
  • Cutout Diameter: 4.2’’
  • Mounting Depth: 2.7’’
  • Speaker Weight: 1.36 lbs. (-Each)
  • Power: 100/240V
BrandPyle Audio
ModelPDICLE35
Part Number310-2468
UPC688887705388
Unit of MeasurePairs
Weight3.62
