  • Pyle PDICBT57 5.25" Bluetooth Home Ceiling Speaker Pair
CLEARANCE Pyle PDICBT57 5.25" Bluetooth Home Ceiling Speaker Pair
Pyle AudioPart # 310-2470
Model: PDICBT57
The Pyle PDICBT87 is a 5.25'' Bluetooth home ceiling speaker system designed to deliver high-quality stereo sound with the convenience of wireless streaming. Ideal for both home and office environments, this system allows for seamless integration into your existing décor by mounting flush to walls or ceilings, providing a clean and unobtrusive audio solution.
  • Bluetooth wireless music streaming for convenient audio playback
  • Powered design removes the need for a separate amplifier
  • Flush-mount design for a clean and unobtrusive appearance
  • Screw terminal block connectors for secure speaker connections
  • Environmentally friendly ABS construction for durability
  • Includes an active and passive speaker for a complete setup
  • Great for custom installations and applications
CLEARANCE $78.92
Save $28.06 (26%)
3 In Stock
We'll send you an email when Pyle PDICBT57 5.25" Bluetooth Home Ceiling Speaker Pair is back in stock or available for preorder.
Order in the next 1 hr 58 min to ship today. Details
The Pyle PDICBT57 includes one active speaker and one passive speaker, along with a 16' speaker connection cable and a power adapter, facilitating straightforward installation. With a maximum power output of 240 watts, the PDICBT87 is engineered to deliver robust and clear sound. With a frequency response ranging from 100Hz to 20kHz, this system offers full spectrum of audio reproduction. The built-in Bluetooth receiver supports a wireless range of up to 40 feet, providing flexibility in device placement and connectivity.
Whether you're setting up a new audio system or upgrading an existing one, the Pyle PDICBT57 offers a combination of modern wireless convenience and high-quality sound performance, all housed within a discreet and aesthetically pleasing design. Its user-friendly installation process and compatibility with a wide range of Bluetooth-enabled devices make it a versatile choice for enhancing your audio experience.
Technical Specifications
  • MAX Power Output: 240 Watt
  • Sound System: 5.25’’ Speaker + 1’’ Tweeter
  • Impedance: 8 Ohm
  • Efficiency: 86dB
  • Frequency Response: 100Hz-20kHz
  • Cut-Out Size: 7.0’’
  • Diameter, 2.9’’ Depth
  • Power: 100/240V, 12V Power Adapter
  • Single Speaker Weight: 3.29 lbs.
BrandPyle Audio
ModelPDICBT57
Part Number310-2470
UPC688887724334
Unit of MeasurePairs
Weight6
