  • Pyle PDIC63T 6.5" In-Wall / Ceiling Speaker Pair 8 Ohm / 70V
NEW Pyle PDIC63T 6.5" In-Wall / Ceiling Speaker Pair 8 Ohm / 70V
Pyle AudioPart # 248-498
Model: PDIC63T
The Pyle PDIC63T is a 6.5-inch in-wall/in-ceiling speaker system designed to deliver high-quality audio with a low-profile, flush-mount design, making it ideal for home, office, or business installations.
  • Built-in 70-volt transformer tapping for flexible installation options
  • 2-way full-range stereo sound for balanced audio reproduction
  • High-impedance, line-matching transformer suitable for amplifier and PA speaker public address systems
  • 1/2'' high-compliance dome tweeter for clear high-frequency sound
  • Poly mica cone with high-sensitivity foam edge for enhanced durability and performance
  • Environmentally friendly ABS construction for long-lasting use
  • Cut-out size template included for easy and precise installation
NEW $44.98
Save $23.01 (34%)
We'll send you an email when Pyle PDIC63T 6.5" In-Wall / Ceiling Speaker Pair 8 Ohm / 70V is back in stock or available for preorder.
Order in the next 3 hr 45 min to ship today. Details
The PDIC63T features a built-in 70-volt transformer tapping, offering flexibility with multiple wattage options (20W, 15W, 10W, 5W, 2.5W) and 8-ohm compatibility, allowing for tailored installations to meet specific audio requirements. Its 2-way full-range stereo sound system combines a 6.5-inch poly mica cone woofer with a high-sensitivity foam edge and a 1/2-inch high-compliance dome tweeter, delivering balanced audio reproduction across various frequencies. The high-impedance, line-matching transformer makes it suitable for integration with amplifier and PA speaker public address systems, enhancing its versatility for different applications. Constructed with environmentally friendly ABS material, the speaker ensures durability and reliability over time. The flush-mount, slim low-profile design allows the speaker to blend seamlessly into walls or ceilings, maintaining the aesthetic integrity of the installation environment. For ease of installation, a cut-out size template is included, facilitating precise and straightforward setup.
Technical Specifications
  • Power Output: 500 Watt MAX
  • Speaker Size: 6.5’’
  • 100V Transformer Tapping at 20W/15W/10W/5W/2.5W and 8 Ohm
  • Impedance: 8 Ohm
  • Frequency Response: 75Hz-20kHz
  • Sensitivity: 92 dB
  • Magnet: 8 oz.
  • Cut-Out Diameter: 7.6''
  • Mounting Depth: 3.35''
  • Total Speaker Size (Diameter x Depth): 8.94" x 3.94"
BrandPyle Audio
ModelPDIC63T
Part Number248-498
UPC842893106922
Unit of MeasurePairs
Weight4.8
Input Rating8 ohm|70V|100V
Mounting StyleIn-ceiling
Woofer Diameter6.5"
