CLEARANCE Pyle PDC22 1/4" Direct Box
We'll send you an email when Pyle PDC22 1/4" Direct Box is back in stock or available for preorder.
Two high-quality direct boxes in one convenient enclosure, the PDC22 offers a variety of DI solutions for live sound and recording applications. You can connect all kinds of audio signals like guitars, keyboards, outboard signal processors and even the high-powered speaker output from an amplifier. The PDC22 enables you to tap off the signal from a guitar or bass guitar and pass the signal from the PARA OUTPUT to the on stage amplifier without affecting the original sound.
Specifications: • Input attenuation: Switchable (0 dB,-20 dB,-40 dB) • Instrument input: 50K unbalanced TS jack • Parallel (Link) out: 50K unbalanced TS jack • Balanced output: 600 balanced XLR jack • Ground lift: Switchable ground lift • Construction: All steel chassis • Dimensions: 5.5" x 4.72" x 1.57".
Product Details | |
| Brand | Pyle Audio |
| Model | PDC22 |
| Part Number | 248-4280 |
| UPC | 068888904117 |
| Unit of Measure | Each |
| Weight | 1.6 |
Product Specifications | |
| Active / Passive | Passive |
| Rack Mountable | No |
