  • Pyle PDA7BU Bluetooth Radio Receiver & Amplifier
CLEARANCE Pyle PDA7BU Bluetooth Radio Receiver & Amplifier
Pyle AudioPart # 310-2692
Model: PDA7BU
The Pyle PDA7BU is a versatile home theater amplifier and audio receiver designed to enhance your audio experience with a range of connectivity options and user-friendly features. With a peak power output of 200 watts, it delivers robust sound suitable for various applications, from home entertainment systems to public address setups. Its rack-mountable design allows for easy integration into existing audio configurations, making it a practical choice for both personal and professional use.
  • Bluetooth wireless streaming for seamless audio playback
  • USB flash drive and SD memory card readers for convenient MP3 playback
  • FM radio with digital LCD display for access to local broadcasts
  • Dual 1/4'' microphone inputs for versatile vocal applications
  • Three RCA inputs to allow for easy switching between sources
  • RCA subwoofer output for powered subwoofer integration
  • Independent input source selection for customized audio control
We'll send you an email when Pyle PDA7BU Bluetooth Radio Receiver & Amplifier is back in stock or available for preorder.
Equipped with Bluetooth 2.1, the PDA7BU enables wireless music streaming from devices such as smartphones, tablets, and laptops, providing flexibility and convenience in audio playback. The inclusion of USB and SD card readers allows for direct playback of MP3 files, expanding your listening options. The built-in FM radio tuner, complemented by a digital LCD display, offers easy access to your favorite radio stations. Dual 1/4'' microphone inputs make the amplifier suitable for events requiring vocal amplification, such as karaoke sessions or public speaking engagements. Three RCA L/R inputs allows for connection of multiple external audio sources, broadening the system's compatibility. The RCA subwoofer output enables the integration of a subwoofer for deeper bass response, enriching the overall sound quality. Independent input source selection allows users to switch between different audio sources effortlessly, tailoring the listening experience to their preferences.
Technical Specifications
  • MAX Power Output: 200 Watt @ 4 Ohm
  • RMS Power Output: 100 Watt x 2 @ 8 Ohm
  • Rated Input currency: 75mA, 8-Ohm Speaker Loaded (30mA, No Load)
  • Construction Material: Metal, Aluminum Alloy Panel
  • Frequency response: 20-20kHz, +/-2dB
  • Signal-to-Noise Ratio (SNR): >85dB
  • Total Harmonic Distortion (THD): <1.0%
  • Input sensitivity: 200mV (Max Output: 6000mV)
  • Maximum USB Flash & SD Memory Card Support Size: 32GB
  • Digital Media File Support: MP3, WAV
  • Battery Operated Remote Control, Requires 3V Lithium Coin Cell
  • Power Cable Length: 4.5’
  • Power: 110/240V, Switchable
  • Dimensions (L x W x H): 19.0’’ x 9.8’’ x 2.2’’
BrandPyle Audio
ModelPDA7BU
Part Number310-2692
UPC842893101484
Weight8.15
