  • Pyle PCBLCO26 Cable Ramp Cord Cover Concealment Protection Track with Flip-Open Top 39.8" L
CLEARANCE Pyle PCBLCO26 Cable Ramp Cord Cover Concealment Protection Track with Flip-Open Top 39.8" L
Pyle AudioPart # 248-4718
Model: PCBLCO26
The Pyle PCBLCO26 cable ramp protective cord cover is perfect for high traffic walking areas. The rugged, durable construction allow for extreme protection and cable concealment. Featuring a flip-open top cover and an interlocking design, running your power lines, extension cables, network cables, and audio cables is hassle free.
  • Rugged and durable construction for protective cable concealment
  • Flip-open top cover for hassle-free cable placement
  • 2,000 lb. load capacity
  • Two channel groove design for running cables
  • Safe in high traffic walking area with anti-slip textured surface
  • Interlocking design allows for multiple connections
  • Great for power lines, extension cables, network cables, and audio cable
We'll send you an email when Pyle PCBLCO26 Cable Ramp Cord Cover Concealment Protection Track with Flip-Open Top 39.8" L is back in stock or available for preorder.
Providing a safe and reliable cable and wire management, the Pyle PCBLCO26 is a great product to conceal your long cables runs. Useful for both indoor and outdoor applications, the bright yellow color makes the cable ramps clearly visible, while the anti-slip texture can handle the stress of high traffic areas. The rugged construction has a 2,000 lb. load capacity. Interconnect multiple tracks for longer cable runs.
Specifications: • Load capacity: 2,000 lb. • Maximum cable diameter: 1.2" • Material: Heavy duty engineered polyethylene • Size: 39.6" L x 9.8" W x 1.9" H • Weight: 14.6 lbs.
BrandPyle Audio
ModelPCBLCO26
Part Number248-4718
UPC068888760638
Weight14.25
