  • Pyle PCAU46BA Stereo Power Amplifier
CLEARANCE Pyle PCAU46BA Stereo Power Amplifier
Pyle AudioPart # 310-2700
Model: PCAU46BA
The Pyle PCAU46BA is a versatile audio speaker power amplifier system designed to enhance your home audio experience with a range of connectivity options and user-friendly features. Delivering up to 2 x 120 watts of peak power at 4 ohms, it provides robust sound quality suitable for various audio setups. Its compact design and comprehensive input options make it an ideal choice for integrating multiple audio sources seamlessly.
  • Bluetooth connectivity for wireless music streaming
  • USB and SD card readers for direct playback of MP3 and WMA files
  • Built-in FM radio tuner for accessing local radio stations
  • Aux (3.5mm) and RCA inputs for connecting external audio sources.
  • Front-panel headphone jack for private listening sessions
  • Adjustable bass and treble controls for personalized sound
  • Remote control included for convenient operation from a distance
We'll send you an email when Pyle PCAU46BA Stereo Power Amplifier is back in stock or available for preorder.
The PCAU46BA amplifier features built-in Bluetooth technology, allowing you to stream music wirelessly from your favorite devices, providing flexibility and convenience in audio playback. Its USB and SD card readers support MP3 and WMA file formats, enabling direct playback without the need for additional equipment. The built-in FM radio tuner expands your listening options, giving you access to a variety of radio stations. With both 3.5mm auxiliary and RCA inputs, the amplifier accommodates a wide range of external audio sources, enhancing its versatility. The front-panel 1/4'' headphone jack allows for private listening sessions. Adjustable bass and treble enable you to tailor the sound output to your liking, ensuring an optimal listening experience. The included remote control adds an extra layer of convenience, allowing you to operate the amplifier's functions from a distance, enhancing user comfort and accessibility.
Technical Specifications
  • 2 x 120 Watt Peak at 4-Ohm
  • Battery Operated Remote, Requires (1) x CR-2025 Button Cell Battery, Included
  • Compatible with Audio/Computer (Device MP3 Players) Via 3.5mm to RCA Converter
  • AC IN Power Cord - Connect to AC 110V/60Hz or 220V/50Hz
  • Frequency Response: 20Hz-20 kHz
  • Voltage Selector: 120/240V
  • Product Dimension ( L x W x H): 5.39’’ x 2.87’’ x 8.41’’
  • Weight: 5.42 lbs.
BrandPyle Audio
ModelPCAU46BA
Part Number310-2700
UPC842893119663
Weight4.95
