The ProMounts UC-PRO320B double sided ceiling TV mount suspends two TVs, one on each side 22" from the ceiling and can extend up to 35.8". Fitting flat and curved LED displays, the mount supports TVs from 37" to 80" and 200x200 to 600x400 VESA patterns. The UC-PRO320B features the unique TouchTilt technology which allows for tool-less adjustments. The fully assembled mount is easy to install while offering post-installation level adjustment and full cable management.
Note that the display screen size is only an approximation. Your display is compatible with this mount as long as it has a VESA mounting pattern and weight that fit within the size and weight limits listed above.
• Display compatibility: 37" to 80" (each side)
• Max load: 99 lbs. (each side)
• VESA patterns: 200x200 to 600x400
• Tilt: -20° to +5°
• Suspension: 22" to 35.8"
