ProMounts AMSA6401 APEX Tabletop TV Stand Mount 37"-70"Built with quality in mind, the AMSA6401 is a new way to mount your TV. The AMSA6401 supports most 37"-70" displays weighing up to 88lbs and the unique design of its universal mounting brackets mean compatibility is almost guaranteed. For precise compatibility, simply check your display’s VESA pattern against the VESA range listed here. If your display’s VESA matches or falls within the range shown, then your display is compatible. It’s that easy.
Made for a modern lifestyle, the AMSA6401 has built-in features that help you get the most out of your display. Integrated cable management allows for easy cable threading and keeps cords out of the way and out of view. This function also ensures that your cables will remain in pristine condition, which will keep the picture quality sharp and provide a pleasurable viewing experience. A secure locking system and simple release offer a way to easily install, adjust, or remove your display from the stand without hassle and an extra wide base help to prevent tipping.
The AMSA6401 is a sleek alternative to wall mounts, its stylish look fits with just about any design space. A high-quality black matte finish gives a modern yet minimalistic look that won’t detract from your set up, making your TV the focal point of the area, all while hiding the hardware. The AMSA6401 is best utilized in spaces that have multiple viewing areas where a swivel range is needed, allowing for versatility when it comes to movement. The swivel capabilities give a ±35° rotation option, affording the perfect view.
A smooth and seamless installation process is what we strive for and all our products are stress and pressure tested with four times their recommended weight limits. This, coupled with quality materials, guarantees that they will not bend or snap under pressure, ensuring your display’s security. Included in the box is an easy to understand manual, complete with demonstrative images that show you the exact steps needed to achieve your perfect viewing experience. For convenience, we have also included multiple screw sizes to ensure compatibility with a wide range of display types.
Display compatibility: 37" to 70"
Max load: 88 lbs.
VESA patterns: 200x200 to 600x400
Swivel: 35°
