  • Precision Port PSP-6RG 6" Connecting Ring for Port Tube
Precision SoundPart # 268-388
Model: PSP-6RG
The Precision Port™ "Create Your Own Port" system allows you to build your own custom length port to your needs using parts made to the same exact standards and tolerances of the original, high performance injected and extruded molded ABS port tube kits from Precision Sound Products.
  • Designed for 6" Precision Port flares
  • Connects flares to port tube or connects flares to each other
  • Sturdy ABS construction made to tight tolerances
  • Proudly made in the USA!
Your Price: $7.25
Save $2.74 (27%)
We'll send you an email when Precision Port PSP-6RG 6" Connecting Ring for Port Tube is back in stock or available for preorder.
Order in the next 11 hr 17 min to ship today. Details
Now you can create your own custom length Precision Port™! Each piece is interchangeable and made to the same exact standards and tolerances of the original, high performance injected and extruded molded ABS port tube kits from Precision Sound Products. Proudly made in the USA!
The PSP-6RG 6" connecting ring slides over the 6" flare (PSP-6OFN), used inside or outside, connecting it to the 6" x 12" port tube (PSP-6TB).
To calculate the proper port length for your cabinet and tuning frequency, use Precision Sound Products' Port Length Calculator.
Dimensions: • Outside diameter: 6-1/4" • Inside diameter: 6-1/8" • Overall length: 1".
BrandPrecision Sound
ModelPSP-6RG
Part Number268-388
UPC848864000602
Weight0.15
