  • Precision Port PSP-2RG 2" Connecting Ring for Port Tube
Now you can create your own custom length Precision Port™! Each piece is interchangeable and made to the same exact standards and tolerances of the original, high performance injected and extruded molded ABS port tube kits from Precision Sound Products. Proudly made in the USA!
The PSP-2RG 2" connecting ring slides over the inside flare (PSP-2IF) or outside flare (PSP-2OFN), connecting them to the 2" x 7" port tube (PSP-2TB). Use multiple connecting rings and port tubes to create long length Precision Ports. You can additionally connect inside and outside flares directly to one another using the connecting ring.
To calculate the proper port length for your cabinet and tuning frequency, use Precision Sound Products' Port Length Calculator.
Dimensions: • Outside diameter: 2-1/4" • Inside diameter: 2-1/16" • Length: 1-1/32".
