  • Plastic Vented Project Box 6.3" x 5.13" x 1.89" with Fold Out Front Legs
CLEARANCE Plastic Vented Project Box 6.3" x 5.13" x 1.89" with Fold Out Front Legs
Parts ExpressPart # 320-423
Read 2 Reviews or
This desktop vented project box works perfect for small ICEpower boards, other small high power amp boards, or any DIY project that requires air circulation. It has built-in standoffs to help secure the board and included leg option to change the viewing angle.
  • Vents on the bottom and top help keep you DIY projects from over heating
  • Includes two rear legs and two front legs that fold out if needed for better viewing angle
  • Built-in standoffs for securely mounting boards
  • Includes four rubber inserts for the legs to help reduce vibration and to prevent unintentional sliding
  • Split case design for easy internal access
We'll send you an email when Plastic Vented Project Box 6.3" x 5.13" x 1.89" with Fold Out Front Legs is back in stock or available for preorder.
Use this vented enclosure to build your next audio amplifier project. ICEpower 50ASX2SE and 50ASX2BTL amp boards line up with two of the built-in stand offs to offer a quick way to secure the board. The project box splits apart making it easy to screw down. It has top and bottom vents to help keep the internal components cool or add and internal fan to keep it even cooler. The smooth front and back plastic panels make it easy to drill holes to add connectors and electronic components. Use the included feet as an option to raise the enclosure for better ventilation, and the front feet fold out to change the viewing angle. Rubber inserts fit into the feet to absorb vibration and to keep your project from sliding around. Use this enclosure's vents to help keep multiple other DIY projects from overheating.
Specifications: • External dimensions: 160 mm W x 130 mm D x 48 mm H without feet • Total internal dimensions: 150 x 110 x 37.9 mm without standoffs • Internal board space available: 126 x 110 mm accessing all standoffs • Standoff spacing: 100 mm W x 94 mm D with 30 mm center spacing and 32 mm outer spacing on each side • Rear leg dimensions when installed with rubber inserts: 14 mm W x 14 mm D x 12mm H • Rear leg dimensions when installed with rubber inserts: 14 mm W x 40 mm D x 12 mm H when folded, 36 mm H unfolded.
Part Number320-423
UPC848864066400
Weight0.46
Construction MaterialABS Plastic
