  • Penn-Elcom 5295+5299 2" Push-In Caster with Metal Socket
Penn-ElcomPart # 262-287
Model: 5295+5299
For heavier duty cabinet applications. Features pressed steel construction and a carrying weight capacity of 100 lbs. per wheel.
Your Price: $10.00
MSRP: $13.99
Save $3.99 (29%)
We'll send you an email when Penn-Elcom 5295+5299 2" Push-In Caster with Metal Socket is back in stock or available for preorder.
For heavier duty cabinet applications. Features pressed steel construction and a carrying weight capacity of 100 lbs. per wheel. Caster snaps in and out for removal later.
Specifications: • 1.97" (50 mm) soft rubber wheel diameter • Shaft measures 0.44" diameter by 1.38" long • Mounting base measures 2.13" diameter and requires 1.38" mounting depth • Penn model 5295+5299 • Sold individually.
BrandPenn-Elcom
Model5295+5299
Part Number262-287
UPC844632052552
Weight0.39
Caster TypeSwivel
Wheel Diameter2"
