  • Peerless by Tymphany HDS-P830869 HDS Series 8" Woofer 8 Ohm
Peerless by TymphanyPart # 264-1007
Model: HDS-P830869
The Peerless FSL-0805R02-08 is an 8″ bass/mid-bass transducer engineered for versatile loudspeaker designs where solid low-frequency performance and smooth midrange are important. It offers a natural tone with balanced efficiency, making it suitable for compact vented boxes or as part of multi-way systems.
  • Cast aluminum frame for rigid structural support
  • Aluminum shorting ring to reduce distortion and improve linearity
  • Vented Nomex cone for controlled cone motion and thermal relief
  • Large excursion capability for extended low-frequency output
Your Price: $61.50
Save $20.50 (25%)
We'll send you an email when Peerless by Tymphany HDS-P830869 HDS Series 8" Woofer 8 Ohm is back in stock or available for preorder.
BrandPeerless by Tymphany
ModelHDS-P830869
Part Number264-1007
UPC848864081441
Weight4.1
Nominal Diameter8"
Bolt Circle Diameter8.31
Power Handling (RMS)30 Watts
Power Handling (MAX)60 Watts
Impedance8Ω
Frequency Response40 to 2000Hz
Sensitivity88.8dB 2.83V/1m
Voice Coil Diameter1.28"
Resonant Frequency (Fs)34Hz
DC Resistance (Re)5.8Ω
Voice Coil Inductance (Le)0.754mH
Mechanical Q (Qms)5.68
Electromagnetic Q (Qes)0.402
Total Q (Qts)0.38
Compliance Equivalent Volume (Vas)2.03ft³
Mechanical Compliance of Suspension (Cms)790mm/N
BL Product (BL)9.34T·m
Diaphragm Mass Inc. Airload (Mms)28.6g
Maximum Linear Excursion (Xmax)7.5mm
Surface Area of Cone (Sd)227cm²
Cone MaterialNomex
Overall Outside Diameter8.07"
Baffle Cutout Diameter7.48"
Depth3.52"
# Mounting Holes6
Sealed Volume0.37ft³
Sealed F383.43Hz
Vented Volume1.305ft³
Vented F340.03Hz
