  • Peerless by Tymphany TC Series TC8FD00-04 3" Full Range Speaker 4 Ohm
Peerless by TymphanyPart # 264-1145
Model: TC8FD00-04
Choose the Tymphany TC Series TC8FD00-04 3", 4-ohm full-range driver for space-limited audio applications. The patented PentaCut NRSC cone damps and controls resonances for superior frequency response from 120 to 20,000 Hz.
  • Patented PentaCut NRSC cone for a flat, damped response
  • Copper capped pole piece reduces inductance and distortion
  • Great for building mini speakers and line array column speakers
Dayton Audio PC83-4 3" Full-Range Poly Cone Driver
Price: $15.49Part # 295-154
Your Price: $13.49
MSRP: $28.99
Save $15.50 (53%)
186 In Stock
We'll send you an email when Peerless by Tymphany TC Series TC8FD00-04 3" Full Range Speaker 4 Ohm is back in stock or available for preorder.
Order in the next 5 hr 46 min to ship today. Details
Tymphany designed the TC Series TC8FD00 to be a cost-effective, high performance 3" speaker for installation in televisions and other compact applications. Ultra-flat frequency response from 130 to 20,000 Hz is made possible by the copper pole piece cap that lowers inductance and distortion, as well as the patented PentaCut NRSC cone that helps dampen and control cone resonances.
With a steel frame that measures less than 3-1/2" wide, this 3" driver is perfect for use in micro monitor 2-way speakers, satellite speakers, and even compact, column line array speakers. For relatively high sensitivity, a 4 ohm voice coil and powerful magnetic motor are used to increase sensitivity to nearly 85.7 dB (2.83V/1m), which is impressive for a driver of this size.
BrandPeerless by Tymphany
ModelTC8FD00-04
Part Number264-1145
UPC848864014999
Weight0.65
Nominal Diameter3"
Bolt Circle Diameter3.37
Power Handling (RMS)25 Watts
Power Handling (MAX)50 Watts
Frequency Response130 to 20,000Hz
Sensitivity85.7dB 2.83V/1m
Voice Coil Diameter0.76"
Resonant Frequency (Fs)125Hz
DC Resistance (Re)3.3Ω
Voice Coil Inductance (Le)0.03mH
Mechanical Q (Qms)3.7
Electromagnetic Q (Qes)1.23
Total Q (Qts)0.92
Compliance Equivalent Volume (Vas)0.03ft³
BL Product (BL)2.32T·m
Diaphragm Mass Inc. Airload (Mms)2.55g
Maximum Linear Excursion (Xmax)2.4mm
Surface Area of Cone (Sd)33.2cm²
Cone MaterialPaper
Overall Outside Diameter3.19" across the flats, 4.76"
Baffle Cutout Diameter3.05"
Depth1.65"
Sealed Volume0.06ft³
Sealed F3122.7Hz
