  • Peerless by Tymphany SLS-135F32CP01-04 5-1/4" Paper Cone Woofer 4 Ohm
Peerless by TymphanyPart # 264-1596
Model: SLS-135F32CP01-04
With a large roll surround, high excursion, and low Fs for its size, the Peerless SLS-135F32CP01-04 5-1/4" subwoofer is ideal for use in extremely compact subwoofer designs, portable 2.1 systems, or even as a woofer in small 3-way systems.
Dayton Audio DC130B-4 5-1/4" Classic Woofer Speaker
Price: $28.98Part # 295-307
See all items in Woofers
Your Price: $39.98
MSRP: $52.99
Save $13.01 (25%)
We'll send you an email when Peerless by Tymphany SLS-135F32CP01-04 5-1/4" Paper Cone Woofer 4 Ohm is back in stock or available for preorder.
Order in the next 3 hr 31 min to ship today. Details
A new addition to the SLS Series of speakers, the Peerless SLS-135F32CP01-04 5-1/4" subwoofer features a paper cone, wide rubber half-roll surround, and hefty ceramic ferrite magnet with distortion-reducing aluminum shorting ring. This driver will provide accurate and detailed low frequency audio reproduction.
The speaker's distinctively sculpted truncated steel frame facilitates close driver spacing or a narrower mounting baffle, and its extensive under-spider venting promotes voice coil cooling for reduced power compression and improved long term reliability. The SLS-135F32CP01-04 will perform superbly as a dedicated low-mid bass driver, as well as delivering solid output when used as a compact subwoofer.
BrandPeerless by Tymphany
ModelSLS-135F32CP01-04
Part Number264-1596
UPC848864045726
Weight2.6
Nominal Diameter5-1/4"
Power Handling (RMS)50 Watts
Power Handling (MAX)100 Watts
Sensitivity86.71dB 2.83V/1m
Voice Coil Diameter1.27"
Resonant Frequency (Fs)51.7Hz
DC Resistance (Re)2.88Ω
Voice Coil Inductance (Le)0.26mH
Mechanical Q (Qms)4.49
Electromagnetic Q (Qes)0.56
Total Q (Qts)0.5
Compliance Equivalent Volume (Vas)0.28ft³
Mechanical Compliance of Suspension (Cms)628mm/N
BL Product (BL)5.02T·m
Diaphragm Mass Inc. Airload (Mms)15.1g
Surface Area of Cone (Sd)95cm²
Cone MaterialPaper
Overall Outside Diameter5.59"
Baffle Cutout Diameter4.65"
Depth3.03"
# Mounting Holes6
Sealed Volume0.25ft³
Sealed F381.8Hz
Vented Volume0.5ft³
Vented F342.9Hz
