  • Peerless by Tymphany SDS-160F25CP01-08 6-1/2" Paper Cone Woofer 8 Ohm
CLEARANCE Peerless by Tymphany SDS-160F25CP01-08 6-1/2" Paper Cone Woofer 8 Ohm
Peerless by TymphanyPart # 264-1592
Model: SDS-160F25CP01-08
The Peerless SDS-160F25CP01-08 is a 6-1/2" 8 ohm compact subwoofer that offers low resonant frequency performance, ideally suited for compact sealed enclosures.
Dayton Audio DC160-8 6-1/2" Classic Woofer
Price: $34.98Part # 295-305
See all items in Woofers
CLEARANCE $23.79
Save $8.20 (26%)
141 In Stock
We'll send you an email when Peerless by Tymphany SDS-160F25CP01-08 6-1/2" Paper Cone Woofer 8 Ohm is back in stock or available for preorder.
Order in the next 8 hr 50 min to ship today. Details
This 6-1/2" 8 ohm member of the SDS family offer a coated paper cone with rubber surround, a high power voice coil suspended in a ferrite magnet motor, and a narrow-profile steel basket, shaped to fit into narrow cabinet.
BrandPeerless by Tymphany
ModelSDS-160F25CP01-08
Part Number264-1592
UPC848864045702
Weight2.15
Nominal Diameter6-1/2"
Power Handling (RMS)60 Watts
Power Handling (MAX)120 Watts
Impedance8Ω
Sensitivity89.46dB 2.83V/1m
Voice Coil Diameter1"
Resonant Frequency (Fs)44.75Hz
DC Resistance (Re)6.05Ω
Voice Coil Inductance (Le)0.38mH
Mechanical Q (Qms)2.74
Electromagnetic Q (Qes)0.55
Total Q (Qts)0.46
Compliance Equivalent Volume (Vas)1.09ft³
Mechanical Compliance of Suspension (Cms)1101.4mm/N
BL Product (BL)5.98T·m
Diaphragm Mass Inc. Airload (Mms)11.5g
Maximum Linear Excursion (Xmax)3.5mm
Surface Area of Cone (Sd)141cm²
Cone MaterialPaper
Overall Outside Diameter6.74"
Baffle Cutout Diameter5.67"
Depth3.06"
# Mounting Holes6
Sealed Volume0.33ft³
Sealed F381.1Hz
Vented Volume0.62ft³
Vented F355Hz
