  • Peerless by Tymphany SBS-160F35AL01-04 6-1/2" Aluminum Cone Woofer 4 Ohm
CLEARANCE Peerless by Tymphany SBS-160F35AL01-04 6-1/2" Aluminum Cone Woofer 4 Ohm
Peerless by TymphanyPart # 264-1564
Model: SBS-160F35AL01-04
5 Questions, 9 Answers or
The Peerless : SBS-160F35AL01-04 is a 6-1/2" 4 ohm woofer that is a member of the new SBS product family.
Pyramid WX65X 6-1/2" White Poly Woofer
Price: $18.50Part # 290-270
See all items in Woofers
We'll send you an email when Peerless by Tymphany SBS-160F35AL01-04 6-1/2" Aluminum Cone Woofer 4 Ohm is back in stock or available for preorder.
The Peerless : SBS-160F35AL01-04 is a 6-1/2" 4 ohm woofer that is a member of the new SBS product family. This driver features a black anodized aluminum cone, inverted rubber surround, ferrite magnet, steel basket. Designed for high excursion applications.
BrandPeerless by Tymphany
ModelSBS-160F35AL01-04
Part Number264-1564
UPC848864045559
Weight3.84
Nominal Diameter6-1/2"
Power Handling (RMS)150 Watts
Power Handling (MAX)300 Watts
Sensitivity82.36dB 2.83V/1m
Voice Coil Diameter1.4"
Resonant Frequency (Fs)46.15Hz
DC Resistance (Re)4.1Ω
Voice Coil Inductance (Le)0.91mH
Mechanical Q (Qms)5.6
Electromagnetic Q (Qes)0.67
Total Q (Qts)0.6
Compliance Equivalent Volume (Vas)0.19ft³
Mechanical Compliance of Suspension (Cms)256.2mm/N
BL Product (BL)9.05T·m
Diaphragm Mass Inc. Airload (Mms)46.4g
Maximum Linear Excursion (Xmax)8.5mm
Surface Area of Cone (Sd)124.7cm²
Cone MaterialAluminum
Overall Outside Diameter6.61"
Baffle Cutout Diameter5.51"
Depth3.69"
# Mounting Holes6
Sealed Volume0.2ft³
Sealed F361.6Hz
Vented Volume0.3ft³
Vented F337.9Hz
