  • Peerless by Tymphany PMT-37N28AL01-04 37mm Aluminum Cone Transducer 4 Ohm
CLEARANCE Peerless by Tymphany PMT-37N28AL01-04 37mm Aluminum Cone Transducer 4 Ohm
Peerless by TymphanyPart # 264-1560
Model: PMT-37N28AL01-04
At just 1.6" diameter and under 1/2" deep, the Peerless PMT-37N28AL01-04 full-range speaker makes it easy to add high quality full-range audio to almost anything. Designed for use in laptops and tablets, this unique driver will provide surprising response from 200 Hz and up.
  • Neodymium motor keeps size and weight at a minimum
  • Composite aluminum diaphragm for impressive off-axis performance
  • Remarkably thin design allows for mounting in almost anything
  • Aluminum diaphragm, rubber surround, and polymer frame for reliable performance
CLEARANCE $14.29
Save $5.70 (29%)
354 In Stock
We'll send you an email when Peerless by Tymphany PMT-37N28AL01-04 37mm Aluminum Cone Transducer 4 Ohm is back in stock or available for preorder.
Order in the next 7 hr 21 min to ship today. Details
The Peerless PMT-37N28AL01-04 37 mm 4 ohm compact micro transducer is designed for laptops, televisions, tablets, and other similar applications. It features a neodymium-iron-boron magnet, a light composite Al cone, and a high-temperature polycarbonate frame to provide reliable performance and impressive efficiency for its size. This unique driver will provide surprising response and output capabilities from 200 Hz and up from spaces where no other driver will fit.
BrandPeerless by Tymphany
ModelPMT-37N28AL01-04
Part Number264-1560
UPC848864044927
Weight0.1
Nominal Diameter1-1/2"
Power Handling (RMS)5 Watts
Power Handling (MAX)10 Watts
Impedance4Ω
Frequency Response200 to 20,000Hz
Sensitivity84.25dB 2.83V/1m
Voice Coil Diameter1.1"
Resonant Frequency (Fs)167.6Hz
DC Resistance (Re)3.58Ω
Voice Coil Inductance (Le)0.06mH
Mechanical Q (Qms)1.28
Electromagnetic Q (Qes)0.5
Total Q (Qts)0.36
Compliance Equivalent Volume (Vas)0.00247ft³
Mechanical Compliance of Suspension (Cms)0.77mm/N
BL Product (BL)3T·m
Maximum Linear Excursion (Xmax)0.1mm
Surface Area of Cone (Sd)7.997cm²
Cone MaterialAluminum
Voice Coil FormerAluminum
Magnet MaterialNeodymium
Overall Outside Diameter1.61"
Baffle Cutout Diameter1.45"
Depth0.465"
Vented Volume0.01ft³
Vented F3131.6Hz
