  • Peerless by Tymphany NE123W-04 4" Paper Cone NE Woofer 4 Ohm
CLEARANCE Peerless by Tymphany NE123W-04 4" Paper Cone NE Woofer 4 Ohm
Peerless by TymphanyPart # 264-1512
Model: NE123W-04
The high fidelity/low distortion Tymphany NE123W-04 4" Neodymium Woofer utilizes advanced design and measurement technologies in combination with carefully selected construction materials.
  • Cast aluminum frame promotes motor cooling
  • Sculpted design improves airflow and reduces reflections
  • High-strength compact neodymium magnet system
  • Proprietary coated natural wood fiber cone with half-roll rubber surround
  • Long-throw 1-1/4" voice coil on titanium former
  • Copper pole piece cap for extended HF response
  • 4 ohm nominal impedance
Dayton Audio RS100-4 4" Reference Full-Range Driver 4 Ohm
Price: $39.98Part # 295-378
See all items in Woofers
CLEARANCE $67.98
Save $22.01 (24%)
30 In Stock
We'll send you an email when Peerless by Tymphany NE123W-04 4" Paper Cone NE Woofer 4 Ohm is back in stock or available for preorder.
Order in the next 6 hr 30 min to ship today. Details
The Tymphany NE123W-04 4" Neodymium Woofer features an innovative sculpted, open cast aluminum basket design that minimizes internal acoustic reflections and supplements the neodymium motor's dedicated heat sink. The cone is constructed of a coated natural wood fiber, with a butyl rubber surround designed by finite element analysis for linearity of performance. FEA techniques also contribute to inclusion of the motor's copper cap, which reduces inductance and extends high frequency performance.
BrandPeerless by Tymphany
ModelNE123W-04
Part Number264-1512
UPC848864045429
Weight0.9
Nominal Diameter4"
Power Handling (RMS)35 Watts
Power Handling (MAX)70 Watts
Impedance4Ω
Frequency Response60 to 8,000Hz
Sensitivity84.9dB 2.83V/1m
Voice Coil Diameter1.28"
Resonant Frequency (Fs)156.4Hz
DC Resistance (Re)3.35Ω
Voice Coil Inductance (Le)0.04mH
Mechanical Q (Qms)3.94
Electromagnetic Q (Qes)0.8
Total Q (Qts)0.67
Compliance Equivalent Volume (Vas)0.024ft³
Mechanical Compliance of Suspension (Cms)1.63mm/N
BL Product (BL)5.09T·m
Diaphragm Mass Inc. Airload (Mms)6.3g
Surface Area of Cone (Sd)54.1cm²
Cone MaterialWood Fiber
Voice Coil FormerTitanium
Magnet MaterialNeodymium
Overall Outside Diameter4.84"
Baffle Cutout Diameter3.86"
Depth2.58"
# Mounting Holes5
Sealed Volume0.08ft³
Sealed F3184.8Hz
Vented Volume0.08ft³
Vented F3114.9Hz
