  • Peerless by Tymphany FSL-0818R01-08 FSL Series 8" Professional Woofer 8 Ohm
Peerless by TymphanyPart # 264-1404
Model: FSL-0818R01-08
The Peerless FSL-0818R01-08 is a high-sensitivity fullrange driver built around a pressed steel basket, paper diaphragm, fabric surround, and ferrite magnet structure. Its feature set offers a straightforward, efficient design suited to applications that benefit from a simple fullrange format and require a strong output.
  • High sensitivity supports stronger output
  • Multi-roll surround Fullrange design keeps the driver focused on broad single-driver coverageand spider have been optimized for reduced distortion
  • Fullrange design supports broad single-driver coverage from one transducer
Dayton Audio Pro 8 in. 8 Ohm Neodymium Midbass Woofer Odeum 8N
Price: $109.98Part # 295-639
Your Price: $45.00
Save $16.00 (26%)
We'll send you an email when Peerless by Tymphany FSL-0818R01-08 FSL Series 8" Professional Woofer 8 Ohm is back in stock or available for preorder.
BrandPeerless by Tymphany
ModelFSL-0818R01-08
Part Number264-1404
UPC848864016948
Weight6.05
Nominal Diameter8"
Bolt Circle Diameter7.818
Power Handling (RMS)250 Watts
Impedance8Ω
Frequency Response70-700Hz
Sensitivity94.4dB 2.83V/1m
Voice Coil Diameter1.8"
Resonant Frequency (Fs)73.9Hz
DC Resistance (Re)5.56Ω
Voice Coil Inductance (Le)0.48mH
Mechanical Q (Qms)3.03
Electromagnetic Q (Qes)0.4
Total Q (Qts)0.35
Compliance Equivalent Volume (Vas)0.53ft³
Mechanical Compliance of Suspension (Cms)0.229mm/N
BL Product (BL)11.49T·m
Maximum Linear Excursion (Xmax)2.2mm
Surface Area of Cone (Sd)217.7cm²
Cone MaterialPaper
Surround MaterialCloth
Overall Outside Diameter8.25"
Baffle Cutout Diameter7"
Depth4"
Sealed Volume0.3ft³
Sealed F3172Hz
Vented Volume0.28ft³
Vented F397Hz
