  • Peerless by Tymphany DFM-2535R00-08 1" Compression Driver 8 Ohm 4-Bolt
NEW Peerless by Tymphany DFM-2535R00-08 1" Compression Driver 8 Ohm 4-Bolt
Peerless by TymphanyPart # 264-1027
Model: DFM-2535R00-08
The Peerless DFM-2535R00-08 is a compression driver designed for efficient high-frequency output in professional speaker systems. Its pure titanium diaphragm and high sensitivity make it a practical choice for designs that need strong output from a compact driver.
  • Pure titanium diaphragm for crisp high-frequency response
  • 107 dB sensitivity for high-output performance
  • 780 Hz resonance frequency for flexible crossover design
  • 25 mm exit diameter for use with compatible horn designs
NEW $42.00
Save $14.00 (25%)
We'll send you an email when Peerless by Tymphany DFM-2535R00-08 1" Compression Driver 8 Ohm 4-Bolt is back in stock or available for preorder.
Order in the next 5 hr 47 min to ship today. Details
  • Exit Diameter: 1 in.
  • Rated Impedance: 8Ω
  • Frequency Range: 1500 - 15000 Hz
  • Sensitivity @ 2.83V/1m: 107 dB
  • Sensitivity @1W/1m²: 107 db
  • Power Rating (IEX 268-5): 25W
  • Minimum Rec. Xover: 1500 Hz
  • Minimum Impedance: 7.5Ω
  • Net Weight: 0.984 kg
  • Voice Coil Diameter: 35.5 mm
  • Voice Coil Material: CCAW
  • Voice Coil Layers: 2
  • Former Material: ASV
  • Diaphragm Material: Titanium
  • Surround Material: Kapton
  • Magnet Type: Ferrite
BrandPeerless by Tymphany
ModelDFM-2535R00-08
Part Number264-1027
UPC848864082967
Weight2.2
Diaphragm MaterialTitanium
Exit Diameter1"
Mounting Type4-Bolt
Power Handling (RMS)25 Watts
Impedance8Ω
