  • Peerless by Tymphany HDS-P835025 6-1/2" Aluminum Cone HDS Woofer
Peerless by TymphanyPart # 264-1086
Model: HDS-P835025
The Peerless High Definition Sound (HDS) Series offers high-quality solutions for multi-way speaker systems employing vented box alignments.
  • Truncated cast aluminum frame
  • Aluminum cone with half-roll rubber surround
  • Long-throw voice coil
  • Shorting rings for reduced distortion
  • Under-spider and voice coil ventilation
Your Price: $64.59
MSRP: $106.99
Save $42.40 (40%)
We'll send you an email when Peerless by Tymphany HDS-P835025 6-1/2" Aluminum Cone HDS Woofer is back in stock or available for preorder.
Estimated back in stock 6/19/2026
The Peerless High Definition Sound (HDS) Series offers high-quality solutions for multi-way speaker systems employing vented box alignments. A powerful ferrite magnet system is coupled to a finite element analysis-designed suspension system, containing a linear spider design and rubber surround. The motor incorporates an aluminum shorting ring that reduces coil inductance, extending frequency response performance and reducing second harmonic distortion. A cast aluminum basket provides high structural rigidity, heat-sinking capacity for the motor, and additional ventilation under the spider that in combination with a vented cone neck reduces air compression effects. The aluminum cone combines high strength with low moving mass, offering superb transient response and sharp definition.
BrandPeerless by Tymphany
ModelHDS-P835025
Part Number264-1086
UPC844632084041
Weight3.1
Nominal Diameter6-1/2"
Power Handling (RMS)50 Watts
Power Handling (MAX)100 Watts
Frequency Response100-3500Hz
Sensitivity86.8dB 2.83V/1m
Voice Coil Diameter1.25"
Resonant Frequency (Fs)43Hz
DC Resistance (Re)6.2Ω
Voice Coil Inductance (Le)0.519mH
Mechanical Q (Qms)3.72
Electromagnetic Q (Qes)0.47
Total Q (Qts)0.42
Compliance Equivalent Volume (Vas)0.67ft³
Mechanical Compliance of Suspension (Cms)0.66mm/N
BL Product (BL)8.58T·m
Diaphragm Mass Inc. Airload (Mms)20.7g
Maximum Linear Excursion (Xmax)10mm
Surface Area of Cone (Sd)143.1cm²
Cone MaterialAluminum
Overall Outside Diameter7.18"
Baffle Cutout Diameter5.72"
Depth3.07"
# Mounting Holes6
Sealed Volume0.25ft³
Sealed F381.4Hz
Vented Volume0.5ft³
Vented F348.2Hz
