  • Peerless by Tymphany HDS-P830874 6-1/2" PPB Cone HDS Woofer
Peerless by TymphanyPart # 264-1090
Model: HDS-P830874
The Peerless High Definition Sound (HDS) Series offers high-quality solutions for multi-way speaker systems employing vented box alignments.
  • Truncated cast aluminum frame
  • PPB polypropylene cone with half-roll rubber surround
  • Long-throw voice coil for high excursion
  • Shorting rings for reduced distortion
  • Under-spider and voice coil ventilation
Your Price: $45.00
Save $15.00 (25%)
We'll send you an email when Peerless by Tymphany HDS-P830874 6-1/2" PPB Cone HDS Woofer is back in stock or available for preorder.
Order in the next 1 hr 15 min to ship today. Details
The Peerless High Definition Sound (HDS) Series offers high-quality solutions for multi-way speaker systems employing vented box alignments. A powerful ferrite magnet system is coupled to a finite element analysis-designed suspension system, containing a linear spider design and rubber surround. The motor incorporates an aluminum shorting ring that reduces coil inductance, extending frequency response performance and reducing second harmonic distortion. A cast aluminum basket provides high structural rigidity, heat-sinking capacity for the motor, and additional ventilation under the spider that in combination with a vented cone neck reduces air compression effects. Peerless developed the proprietary and highly advanced Polypropylene Black (PPB) cone material used in the HDS PPB Series, creating a stiff but still dampened cone that remains stable even under the greatest sound pressures.
BrandPeerless by Tymphany
ModelHDS-P830874
Part Number264-1090
UPC844632084065
Weight3.7
Nominal Diameter6-1/2"
Power Handling (RMS)50 Watts
Power Handling (MAX)100 Watts
Frequency Response50 to 4,000Hz
Sensitivity88.5dB 2.83V/1m
Voice Coil Diameter1.25"
Resonant Frequency (Fs)58Hz
DC Resistance (Re)6.5Ω
Voice Coil Inductance (Le)0.42mH
Mechanical Q (Qms)2.3
Electromagnetic Q (Qes)0.53
Total Q (Qts)0.43
Compliance Equivalent Volume (Vas)0.44ft³
Mechanical Compliance of Suspension (Cms)0.43mm/N
BL Product (BL)8.82T·m
Diaphragm Mass Inc. Airload (Mms)17.34g
Maximum Linear Excursion (Xmax)5.38mm
Surface Area of Cone (Sd)143cm²
Cone MaterialPoly
Overall Outside Diameter7.18"
Baffle Cutout Diameter5.72"
Depth3.44"
# Mounting Holes6
Sealed Volume0.2ft³
Sealed F3106.8Hz
Vented Volume0.5ft³
Vented F353.5Hz
