  • Peerless by Tymphany SLS-P830669 12" Paper Cone SLS Subwoofer
Peerless by TymphanyPart # 264-1118
Model: SLS-P830669
The Peerless SLS Series combines high quality performance with an affordable design.
  • Premium sculpted stamped steel chassis
  • Coated paper cone with rubber edge
  • Shorting ring in magnet system
Dayton Audio RSS315HFA-8 12" Reference Series HF Subwoofer 8 Ohm
Price: $239.98Part # 295-445
LaVoce SSF122.50L 12" Paper Cone Subwoofer
Price: $179.00Part # 293-788
Your Price: $76.50
Save $25.50 (25%)
We'll send you an email when Peerless by Tymphany SLS-P830669 12" Paper Cone SLS Subwoofer is back in stock or available for preorder.
Estimated back in stock 12/4/2026
The Peerless SLS Series combines high quality performance with an affordable design. The SLS drivers are ideal for use in systems with high power handling requirements, and are a logical choice for use with the SDS line of transducers.
BrandPeerless by Tymphany
ModelSLS-P830669
Part Number264-1118
UPC844632084201
Weight8.35
Nominal Diameter12"
Bolt Circle Diameter12
Power Handling (RMS)110 Watts
Power Handling (MAX)220 Watts
Impedance8Ω
Frequency Response30 to 2,000Hz
Sensitivity89.8dB 2.83V/1m
Voice Coil Diameter1.5"
Resonant Frequency (Fs)31Hz
DC Resistance (Re)5.6Ω
Voice Coil Inductance (Le)1.12mH
Mechanical Q (Qms)7.1
Electromagnetic Q (Qes)0.58
Total Q (Qts)0.54
Compliance Equivalent Volume (Vas)4.68ft³
Mechanical Compliance of Suspension (Cms)0.35mm/N
BL Product (BL)11.88T·m
Diaphragm Mass Inc. Airload (Mms)74.11g
Maximum Linear Excursion (Xmax)8.3mm
Surface Area of Cone (Sd)522.8cm²
Cone MaterialCoated Paper
Overall Outside Diameter12.38"
Baffle Cutout Diameter10.91"
Depth5.95"
Sealed Volume2.4ft³
Sealed F347.4Hz
Vented Volume3ft³
Vented F335.4Hz
